Is it possible to multisession a DVD-R
Discussion in 'PC Hardware' started by alboy, 2004/07/10.
  1. 2004/07/10
    alboy
    alboy Well-Known Member Thread Starter
    Hi
    When I copy photo files etc to a blank cdr i always use the multisession option in Nero Express as i like to add extra files as required but when i try the same thing using a DVD-R i get an error message telling me that previous files will not be seen if i use that option surely you should be able to multisession a DVD-R as i always thought it was just a high capacity cdr any advice and help would be appreciated.
  2. 2004/07/11
    Hi alboy,
    Could it be just a warning that a multisession may not work? You don't say that you have tried making one or does it not let you proceed.
    From the readme of Sonic RecordNow DX:
    "8. Windows 98/ME does not read multi-session DVDs properly
    Windows 98/ME systems can only read the first session recorded to an
    appendable DVD disc. If you open an appendable
    DVD on a Windows 98/ME system and some files appear to be missing, try
    opening the disc on a computer running a different operating system.
    9. Possible DVD data loss with Windows 2000/XP
    Sonic RecordNow DX allows you to make multiple recordings to a single DVD.
    However, a serious problem can occur on Windows 2000 and XP systems
    once the total amount of data or music recorded during multiple jobs
    exceeds 4 GB. Once the total amount of data or music exceeds 4 GB,
    only the first recording job placed on the disc will be visible to
    your computer. This problem does not affect single recording jobs
    larger than 4 GB.
    Microsoft has been working to fix this problem. For more information,
    please visit the Microsoft support center at
    http://support.microsoft.com and search for document Q329112. "
