IRQL_NOT_LESS_OR_EQUAL while booting winxp pro
Discussion in 'Windows XP' started by avinashk, 2005/08/24.
  1. 2005/08/24
    avinashk
    avinashk Inactive Thread Starter
    For some days i am getting BSOD while starting winxp pro
    can anyone help .. here is the bugcheck
    Microsoft (R) Windows Debugger Version 6.5.0003.7
    Loading Dump File [C:\WINDOWS\Minidump\Mini081705-01.dmp]
    Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
    Executable search path is: F:\INSTALL\WINXP\I386
    Windows XP Kernel Version 2600 UP Free x86 compatible
    Product: WinNt
    Built by: 2600.xpclient.010817-1148
    Kernel base = 0x804d0000 PsLoadedModuleList = 0x80545b28
    Debug session time: Wed Aug 17 12:09:34.355 2005 (GMT+6)
    System Uptime: 0 days 2:18:55.156
    Loading Kernel Symbols
    Loading unloaded module list
    Loading User Symbols
    * Bugcheck Analysis *
    BugCheck D1, {34, 2, 0, f848ab74}
    Unable to load image IdeChnDr.sys, Win32 error 2
    *** WARNING: Unable to verify timestamp for IdeChnDr.sys
    *** ERROR: Module load completed but symbols could not be loaded for IdeChnDr.sys
    Probably caused by : IdeChnDr.sys ( IdeChnDr+5b74 )
    Followup: MachineOwner
    kd> .reload
    kd> !analyze -show
    Unknown bugcheck code (0)
    Unknown bugcheck description
    Arguments:
    Arg1: 00000000
    Arg2: 00000000
    Arg3: 00000000
    Arg4: 00000000
    kd> !analyze -v
    DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If kernel debugger is available get stack backtrace.
    Arguments:
    Arg1: 00000034, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: f848ab74, address which referenced memory
    Debugging Details:
    READ_ADDRESS: 00000034
    CURRENT_IRQL: 2
    FAULTING_IP:
    IdeChnDr+5b74
    f848ab74 0fb65834 movzx ebx,byte ptr [eax+0x34]
    CUSTOMER_CRASH_COUNT: 1
    BUGCHECK_STR: 0xD1
    LAST_CONTROL_TRANSFER: from f848aaa7 to f848ab74
    LOCK_ADDRESS: 80543c60 -- (!locks 80543c60)
    Resource @ nt!PiEngineLock (0x80543c60) Available
    WARNING: SystemResourcesList->Flink chain invalid. Resource may be corrupted, or already deleted.
    WARNING: SystemResourcesList->Blink chain invalid. Resource may be corrupted, or already deleted.
    1 total locks
    PNP_TRIAGE:
    Lock address : 0x80543c60
    Thread Count : 0
    Thread address: 0x00000000
    Thread wait : 0x0
    TRAP_FRAME: f898e760 -- (.trap fffffffff898e760)
    ErrCode = 00000000
    eax=00000000 ebx=81f4736c ecx=81f1a480 edx=00000000 esi=81f4736c edi=00eabee9
    eip=f848ab74 esp=f898e7d4 ebp=f898e7e0 iopl=0 nv up ei ng nz ac po cy
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010297
    IdeChnDr+0x5b74:
    f848ab74 0fb65834 movzx ebx,byte ptr [eax+0x34] ds:0023:00000034=??
    Resetting default scope
    STACK_TEXT:
    f898e7e0 f848aaa7 81f4736c 00000000 81f4736c IdeChnDr+0x5b74
    f898e80c f8488e6a 00f4736c 81f470e0 81f18c50 IdeChnDr+0x5aa7
    f898e834 804ec04f 81f45030 81f18c50 f84fc0fa IdeChnDr+0x3e6a
    f898e844 f84fc121 f84fc0fa f84fc886 81f41ac0 nt!IopfCallDriver+0x31
    f898e84c f84fc886 81f41ac0 81f18c50 81f18d08 ACPI!ACPIDispatchForwardIrp+0x27
    f898e87c 804ec04f 81f41ac0 f851060c 81e83620 ACPI!ACPIDispatchIrp+0x158
    f898e88c f8593cf1 804ed7c2 81fd0c00 00000000 nt!IopfCallDriver+0x31
    f898e89c f8595d41 81e83620 81fd0b48 81fd0b48 CLASSPNP!SubmitTransferPacket+0x7e
    f898e94c f8584f7d 81fd0b48 81fd0c00 f8587f60 CLASSPNP!ClassReadDriveCapacity+0x96
    f898e958 f8587f60 81fd0b48 81fd0de8 81fd0c00 disk!DiskReadDriveCapacity+0x21
    f898e978 f859a092 81fd0b48 c00000bb 00000000 disk!DiskEnumerateDevice+0x1a
    f898e98c f859ac32 81fd0b48 81a26b20 81fd09d8 CLASSPNP!ClassPnpQueryFdoRelations+0x32
    f898e9b8 804ec04f 81fd0b48 81a26b20 81a26c18 CLASSPNP!ClassDispatchPnp+0x52f
    f898e9c8 f87cdb3a 81a26bfc 81fd09d8 81a26b20 nt!IopfCallDriver+0x31
    f898ea04 f87ce01c 81fd09d8 81a26b20 81a26c20 PartMgr!PmQueryDeviceRelations+0x4d
    f898ea40 804ec04f 81fd0920 81a26b20 f898eabc PartMgr!PmPnp+0x18b
    f898ea50 8055b50d 00000000 81f41860 81f41860 nt!IopfCallDriver+0x31
    f898ea7c 80505cc8 81fd0920 f898ea98 81f41940 nt!IopSynchronousCall+0xb8
    f898eabc 805adb93 00000000 81f45030 00000001 nt!IopQueryDeviceRelations+0x39
    f898ead0 805adb66 81f41860 00000001 81f41860 nt!PipEnumerateDevice+0x20
    f898ed18 805af082 81f41860 00000001 00000000 nt!PipProcessDevNodeTree+0x1b1
    f898ed4c 805057fa 00000003 80543d40 80548abc nt!PiProcessReenumeration+0x5e
    f898ed74 804ebd08 00000000 00000000 81fccb30 nt!PipDeviceActionWorker+0x133
    f898edac 80559026 00000000 00000000 00000000 nt!ExpWorkerThread+0xfe
    f898eddc 8050f513 804ebc35 00000001 00000000 nt!PspSystemThreadStartup+0x34
    00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
    FOLLOWUP_IP:
    IdeChnDr+5b74
    SYMBOL_STACK_INDEX: 0
    FOLLOWUP_NAME: MachineOwner
    SYMBOL_NAME: IdeChnDr+5b74
    MODULE_NAME: IdeChnDr
    IMAGE_NAME: IdeChnDr.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 3d99eac3
    STACK_COMMAND: .trap fffffffff898e760 ; kb
    FAILURE_BUCKET_ID: 0xD1_IdeChnDr+5b74
  2. 2005/08/24
    vbmark
    vbmark Inactive
    I would boot off of my XP cd and do a "Repair Windows ".
    Remember to restall SP2 and any other, new updates.
    charlesvar
    charlesvar Inactive Alumni
    cpc2004
    cpc2004 Inactive
    oshwyn5
    oshwyn5 Inactive
    Generally, an IRQL_NOT_LESS_OR_EQUAL error indicates you have a bad driver.
    Updating the driver in question will solve it.
    Most of the time it turns out to be the video card driver.
    Arguments:
    This indicates that whatever device assigned memory address f848ab74 tried to read from memory address 00000034 did not have the correct permissions for that address.
    By going to control panel/ system / hardware /device manager and selecting devices one at a time and checking their properties / resources you will find one which has a memory range (note some devices will have more than one assigned) which includes f848ab74, probably something like f8000000 -f8ffffff
    . You just update the driver.
    Occaisionally this is caused by an incompatible bios entry , and you need to update (flash ) your bios, but this is rare and flashing the bios should be a last resort.
    To quote microsoft
    "Cause
    A driver tried to access an address that is pageable (or that is completely invalid) while the IRQL was too high.
    This bug check is usually caused by drivers that have used improper addresses. "
  7. 2005/08/29
    avinashk
    I had removed Intel Application Accelerator and also delete virtual memory and recrete it.
    After that error is gone.
    Thanx Everybody for posting.
  8. 2005/08/29
    oshwyn5
    oshwyn5 Inactive
    This is not the first time I have heard of Intel Application Accellerator causing problems. There was a flurry of similar problems when windows update was misidentifying motherboard chipsets and suggesting it for non Intel based motherboards. I thought that had been corrected though.
