Inverted comma not showing
Discussion in 'Windows XP' started by Gilven, 2007/09/27.
  1. 2007/09/27
    Gilven
    Gilven Inactive Thread Starter
    Hi All
    I have had this problem for a while now and I know it is a setting somewhere.
    When I type on the keyboard and hit inverted commas ( ") they only appear once I press the following key. It is quite annoying when I do web pages etc. also when I type something that starts with a,e,i,o or u (for example "egg ") the e will pop up like ë when I hit it. So typing it i have to do the following
    <inverted commas><space><e><g><g><inverted commas><space><space>
    the single inverted comma will result in é.
    How do I get rid of this?
    Thanks:confused:
  2. 2007/09/27
    Have you tried removing the keyboard through Device manager and rebooting?
    Have you tried another keyboard? If a laptop have you tried plugging in an external keyboard?
    Have you checked that you are using the correct keyboard language for your locale? ....
    Control Panel > Regional & Language > Languages > Details
    Gilven
    Bummer...
    I have tried various options. (this is a desktop though) From PS2 Keyboards to USB keyboards even the on-screen keyboard. So we are definitely not looking at hardware.
    I did notice that the on-screen keyboard displays the ~and the " the same as the other keys like ctrl alt and shift.
    Any more ideas when it comes to settings though?
  5. 2007/09/27
    Gilven
    Thanks for pointing me in the right direction.
    I solved the problem by deleting all the languages and adding a new one.
    Cool:)
  7. 2007/09/27
    Glad to get that sorted :) Thanks for the update.
