internet explorer will not install flash player activex
Discussion in 'Internet Explorer & Microsoft Edge' started by rockoreid1, 2008/02/12.
  1. 2008/02/12
    rockoreid1
    rockoreid1 Inactive Thread Starter
    when I try to install flash player. My bar tells me that this site is acting in a unsafe matter and cant download the activex. i have tried everything. What can I do? thank you
  2. 2008/02/12
    pishbloom2
    pishbloom2 Well-Known Member
    first try looking in your add/remove programs. if u have it it will say adobe flash player 9 active x 2.33mb. if not u dont have it. to get it go to www.softwarepatch.com and under software look for adobe flash player 9 stand alone download 4.33 mb. then check your add/remove programs and it should be listed. hope this helps u.
    Christer
    Christer Geek Member Staff
    Hello rockoreid1,
    welcome to WindowsBBS ... :) ... !
    Which browser are you using? The procedure is different in IE6/IE7 (direct installation from Adobes site) compared to Firefox (downloading of a file to the computer and installing from there).
    Christer
  5. 2008/02/12
    rockoreid1
    internet explorer will not instal flash
    Thank you Christer and pishbloom2. I got it fixed, I used the standalone download. It worked like a charm. Thanks again. Rockoreid1:)
