Internet Connection Sharing with AOL -- Possible?
Discussion in 'Other PC Software' started by quackbal, 2004/02/19.
  1. 2004/02/19
    quackbal
    quackbal Inactive Thread Starter
    My friend has AOL broadband, and has recently networked his computers.
    Is it actually possible to share an internet connection on AOL so both computers can be online at the same time, or can this not be done?
    Help appreciated.
  2. 2004/02/19
    At a guess and without ever having messed with AOL, I'd say it will probably work unless AOL has some sort of requirement for login authentication and blocks the same ID from multiple simultaneous logins.
    Certainly be easy enough to try.
    Could be trouble... Depending on the OS. This is for Windows 98:
    How to Use AOL with Internet Connection Sharing
    quackbal
    Hello,
    Thanks for the replies. However, I'm running Windows XP (host) and Windows 2000 (client)
  6. 2004/02/20
    Well, I didn't find any other info on the MS support site about it, and have no other info about it myself.
    AOL isn't your standard ISP however, so it could give trouble.
    Might be worth looking at other (software/hardware) solutions.
  7. 2004/02/20
    Have you tried doing it and had trouble?
    #6
  8. 2004/02/20
    BillyBob Inactive
    I do not know about using Internet Connection Sharing but I bet a Router would allow it to happen.
    Until I found out that it was installed on another machine one of the Neices was using AOL ( not for BroadBand ) at the same time I was on RoadRunner.
    BillyBob
  9. 2004/02/22
    quackbal
    Whoopee
    Hey,
    Just to let you know - all is well. I found some proxy software and installed it on the host machine and asked the non-AOL machine to use that proxy, and it works as well as a computer works with AOL! :)
    Thanks for the help.
  10. 2004/02/23
    Great news and thanks for posting back.
    #9
