Intermittent connection
Discussion in 'Networking (Hardware & Software)' started by warpy55, 2013/05/01.
  1. 2013/05/01
    warpy55
    warpy55 Well-Known Member Thread Starter
    I travel away to another part of our country and I log in at a motel using the wireless connection. I then access our VPN and from there seem to have intermittent connection at the motel I stay at. Every few seconds while logged in thru VPN I can type and nothing appears on the screen it just sits locked up. After about 30 seconds it will add in what I have typed, only to repeat this a few seconds later. I try the same setup at a cafe and log in to their wireless and I get no lock outs. I have tried at the motel, time and time again. Signal levels seems fine. I have tried different locations at the motel at get the same lockout result. I am using XP. What should I try, or check to solve this problem??
    Outside of the VPN I have no issues, I don't get a lockout.
  2. 2013/05/01
    Have you tried it from the lobby which should be pretty close to their router?
    warpy55
    Hi Bill,
    Thanks for reply.
    I just tried it in the lobby and checked the router was near and problem still persists.
  5. 2013/05/01
    The problem is not the wifi connection, the problem is due to the hotel's bandwidth being to low, or the hotel's network firewall/router. Its router may not be configured properly for VPN passthrough.
    warpy55 likes this.
  6. 2013/05/02
    warpy55
    Hi Tony,
    Thanks I will advise the hotel to see if we can get them to increase bandwidth and or ensure configured for VPN. I won't know till next month when I visit again.
  7. 2013/05/23
    aPod
    aPod Well-Known Member
    If you try running a constant PING to let's say google.com you can see the fluctuation in the bandwidth.
    let us know how you get on
    aPod,
    #6
