Intallation help needed
Discussion in 'Legacy Windows' started by Sherri, 2003/02/17.
  1. 2003/02/17
    Sherri
    Sherri Inactive Thread Starter
    Can someone help me please?
    I have a computer at home that the hard drive died on last week:confused:
    A new one has been installed but I cannot load an operating system on it.
    I've tried using boot disks where it will go through a check and put some files on, fires up the CD and starts to install but then it just goes back to A:/ prompt.
    What am I doing wrong?
    Help!
    Sherri
  2. 2003/02/17
    KevinSaul
    KevinSaul Inactive
    Did you run fdisk?
    Did you format it?
    markp62
    markp62 Geek Member Alumni
    Here is how to use fdisk and format to ready the HD for Win9x.
    At A:\> type fdisk enter
    press "Y" enter for large disk support << Y=FAT32, N=FAT16, choose N for 95, Y for 95b,98; if using 95 boot floppy you will not see this.
    at FDISK Option select "1" enter
    at Create DOS Partition or logical DOS Drive select "1" enter
    Verifying drive integrity, **%
    press "Y" enter at do you wish to use the maximum available size for Primary DOS Partition
    and make the partition active (Y/N)..?
    If you want to partition the disk set the size of your primary.
    you then get a message to RESTART your system for changes to take effect
    To create a second partition, you must create a extended partition and then create the logical drive(s) or other partitions.
    YOU MUST REBOOT and format AFTER FDISK.
    Press Esc and then Ctrl,Alt,Del, with bootdisk/Startup disk still in the floppy drive
    At windows Startup Menu select without CD-Rom support
    at A:\> type format c: (this will only format the HDD)
    or A:\> type format c: /s (this will format and make HDD bootable)
    At WARNING, ALL DATA WILL BE LOST PRESS "Y "
    Formatting and the size of your HDD (i.e. 19,09.84M for a 20Gig)
    after format enter a name for the HDD or just press enter you can name it later
    Press Ctrl,Alt,Del, to reboot with bootdisk/startdisk in floppy
    Select with CD-Rom support
    enter A:\>C:\
    and C:\>dir to see HDD space (i.e. 19,083.48 MB free for 20Gig)
    Install Windows.
  5. 2003/02/21
    alboy
    alboy Well-Known Member
    Try this Site
    Try HERE it gives plenty of info on Re-Installing Win 95
