Installing XP Pro on 98SE comp - how to format?
Discussion in 'Windows XP' started by mccoady, 2006/07/13.
  1. 2006/07/13
    mccoady
    mccoady Inactive Thread Starter
    My nephew and I are trying to install XP Pro on a computer that already has 98SE on it and neither of us know how to reformat the drive. Is there any simple instructions for us to replace 98 with XP on our computer? I'm hoping between the two of us if the instructions aren't too complicated we may be able to do this. I don't need to save any data just want to set this up for internet use only. I don't think it has any partitions.
  2. 2006/07/13
    charlesvar
    charlesvar Inactive Alumni
    mccoady
    The site you listed says you cannot upgrade from 98SE to XP Pro but I just read on Microsoft website that you can so which is it?
  5. 2006/07/14
    I think you have misinterpreted the article although it ould have been wrtten a little clearer ....
    The only here means that you cannot upgrade to XP Home from NT 4 or W2k or from XP Home of course.
    I hope that's clear :D
  6. 2006/07/14
    charlesvar
    Hi mccoady,
    You write "neither one of us know how to reformat the drive ". That means you're attempting a clean install, not an upgrade.
    Once you're doing that, than upgrading from what OS to what OS is not an issue.
    Another reference: http://www.michaelstevenstech.com/cleanxpinstall.html
    Regards - Charles
  7. 2006/07/14
    BillyBob Inactive
    Yes you can.
    The HD that I am on right now is a COPY of a 40gig that started out with Win95. Then upgraded to o 98 Then to 98SE and is now XP Pro and has not been formated inbetween.
    But I MUST add that I believe there may be more than one version of Win95 which might make a difference.
    I got a lot of remarks about living dangerously. They are right. But i had NOTHING to lose as I still had the other machine. Alias/ BACKUP/
    I think that if I had only had the one machine I still would have copied the HD and set the original aside.
    BillyBob
  8. 2006/07/14
    BillyBob Inactive
    Something VERY IMPORTANT when upgrading overtop that I forgot.
    You do need to watch carefully and make sure the new OS goes into the existing Windows Directry.
    BillyBob
  9. 2006/07/14
    mccoady
    Okay we will try to do this.
