Installing 7 from USB (current XP)
Discussion in 'Windows XP' started by Stoliguy, 2013/09/17.
  1. 2013/09/17
    Stoliguy
    Stoliguy Inactive Thread Starter
    If this is a repost, please direct me. The searches I've done come up with stuff that's close, but doesn't seem to work...
    I have XP SP3 on what started life as a Gateway (4100?)... the Mobo is all that's left of the original computer. XP runs fine, but is slowing down due to all the **** that's been installed/uninstalled over the years... I'd like to upgrade to 7... one of the gremlins is that some unseen piece of spamware **** has made my CD drive useless. The drive works in other PCs, but NO drive works in this one... I've run into it before, and a clean install fixed it... so.....
    So I created a bootable USB using UltraISO with Win7...
    BIOS select the USB to boot, and get an error about "windows failed to start" telling me I don't have the disc "\Boot\BCD" and status "0xc000000e "
    Tells me to install my windows disc.
    any ideas?
  2. 2013/09/17
    SpywareDr
    Stoliguy
    It doesn't. (give the error)
  5. 2013/09/17
    James Martin
    James Martin Geek Member
    Have you tried Rufus?...
    http://rufus.akeo.ie/
    It may not solve your current problem, but, who knows, it may be worth a try.
  6. 2013/09/18
    Stoliguy
    It didn't... but thank you for the info.
    I ended up downloading a install-from HD version.. not what I wanted, but it'll suffice.
  7. 2013/09/18
    Stoliguy
    well... you win some, you lose some...
    I decided on a "load from HDD" version of 7... I got it.. but now can't seem to make 7 see my AGP video card... GRR...
    off to post in the "7" section...
