Installation Problem in XP
Discussion in 'Windows XP' started by mukundh, 2002/03/28.
  1. 2002/03/28
    mukundh
    mukundh Inactive Thread Starter
    I have a problem in Windows XP Professional Installation
    When i try upgrading from Windows 98 to Windows XP :-
    I start Windows XP Installation and choose upgrade , then i accept the agreement and enter the serial key. Then it shows u an upgrade report where it tells me that my Creative 56K V90 Modem and My HP Scanjet 3400C would have a problem. I have my drivers for the Modem in Windows XP. After this is copies the Installation files int he HDD and restarts. After it restarts its shows a indicator saying Loading Windows XP Setup. After that it says Please Wait and then there is no activity in my HDD nor in my CD Drive. The Computer stops in that screen.
    When i try Installing XP ( Fresh Installation ) :-
    I start Windows XP Installation and choose Fresh Install , then i accept the agreement and enter the serial key. After this is copies the Installation files int he HDD and restarts. After it restarts it takes me to a Blue Color Screen . It first says press F6 to install SCSI or RAID Drivers. then the screen changes and asks to press F2 for ASR. then it says "Setup is Loading Windows XP ". The screen stops there and there is no activity in my HDD nor in my CD Drive. The Computer stops in that screen.
    I have used Windows XP Before in my PC. THis problem started only after i formatted my PC. I installed Windows XP from the same CD.
    I also tried installing Windows Whistler RC2 and Windows 2000. The same problem occurs there also.
    Please let me know a solution
  2. 2002/03/28
    Rancher
    Rancher Inactive
    mystery
    You say a clean format & install? What ute did you use to format? Don't use the startup win98 disk, instead set you bios to "first device=cdrom, second device=c third device=a save/exit have your winxp in tray. Setup will rebuild a partition & format a non dos table for your winxp. When asked for verify previous windows place win98 cd in tray & point to this location, continue, etc: Now you may have errors on the hard drive so let the setup check for these too. You will never get the thang to work rite if bad sectors show on the hard drive where the OS is to be installed:)
    mukundh
    I went to MS DOS and formatted my c drive at the command promt " format c: "
    then i started my pc with my windows 98 bootable cd and installed windows 98
    then after that when i choose upgrade i get the problem i mentioned above
  5. 2002/03/28
    Rancher
    Rancher Inactive
    dos/clean/fresh
    Re-reading your first post, fresh install just replaces a botched previous attempt @ install! Clean is to install into a partition w/no other OS installed. You may want to try a dual boot if your drive is large nuf. BTW what is this box we are fix n? Ram, proc, etc? The partition where winxp lives really works best in a "clean" install. This way the tables are adjusted primarily for xp. If you already have win98 on this drive, and want to still upgrade "over" win98, then remove all cards but video & try again :)
  6. 2002/03/28
    mukundh
    i have used dual boot with this same PC before.. i have both windows 98 and windows XP.
    but i had previously installed windows XP twice and i did not face any problem
    after formatting my drive , i tried booting with the WINXP CD and installing. but the same error came. it stopped in the screed saying " Setup is loding Windows XP "
    thats y i installed windows 98 and tried to upgrade.
    thanks
  7. 2002/03/28
    Rancher
    Rancher Inactive
    got it
    http://www.windowsreinstall.com/indexwinxp.htm This site may have the trick for ya:) The best way I've found when the install hangs is to remove all cards but the video. It seems the install on yours does not get to searching hardware so we have to look for probs on hard drive, in bios, memory free, blah blah
    anyone else out there gotta clue?
  8. 2002/03/29
    mukundh
    thanks
  9. 2002/03/29
    mukundh
    hello there
    i had asked a friend of mine about the same problem... he told me the following :-
    " you have a compressed volume overlay on that disk
    i dont care if you format the disk fdisk or use delpart. it will still be there!!!!!
    you have to write the disk back to 0's
    the easiest way to do so is go to your hard drive manufacture's site and get their utility to do so.
    if you cant find the file. call them
    Hard drive companies like wd and maxtor will be glad to assist you
    when done a write to zeros you hd will be considered recertified so if you are using a win 9x you must fdisk and format in 2000 and xp this will be done for you
    as a word of advice if you are using this computer at home use fat 32 as it is way faster in every aspect use ntfs for business caus it is secure and less volnerable to errors "
    I would like to know what do u mean by writing the disk back to zero ??????/ Will i lose my data if i do so ????
    Please help
  10. 2002/03/29
    Rancher
    Rancher Inactive
    doubt
    copied over from those in dah no.....
    compressed hard drive
    ..." Subject: compressed hard drive. I wanted to install win 98/win XP. When I run setup it performs
    a check on my system, then it says, setup found a compressed volume or ..." But if in doubt go here and see what they say!
    www.smartcomputing.com/editcat/SMART/STORAGE/158/9887/
  11. 2002/03/31
    mukundh
    Rancher
    Rancher Inactive
    in doubt, try
    Maybe but what are we trying to do here? You have already formated & have had win98 & winxp with dual boot on this drive, rite? Your post is copied below.
    "I went to MS DOS and formatted my c drive at the command promt " format c: "
    then after that when i choose upgrade i get the problem i mentioned above "
    So can you partition & format this way again? If not boot to A drive with win98 boot disk & select NO CDROM support, now type this at the prompt A:\scandisk when ask to do a thorough surface scan click yes:)
  13. 2002/04/01
    mukundh
    hello there
    i did scandisk in both my partitions with surface scan.. there were no bad sectors in it...
    what to do next ??
  14. 2002/04/01
    Rancher
    Rancher Inactive
    try install
    Well then lets install winxp! Put xp incdrom, bootup & enter Bios. Set first boot device=cdrom second=c save/exit, the setup begins from the cdrom. Winxp will check the disk, partition & format things to suite itself so ta speak. Don't panic give it time to install. If a script pops up about drives not certified say go ahead anyway, xp rules:D
  15. 2002/04/01
    mukundh
    i tired it
    same problem man
    no change..............
    what to do?????/
  16. 2002/04/01
    Rancher
    Rancher Inactive
    answer this
    can you answer these ??
    1=what box is this, Dell, compaq, gatway, micron
    2=how big hard drive model# make
    3=CPU, memory, mainboard maker model#
    We need to know if there is a bios overlay here. Something ain't right man:confused:
  17. 2002/04/01
    mukundh
    My PC COnfig
    AK72 Aopen MotherBoard
    800MHZ AMD Athalon Processor
    15 GB Quantum Fireball HDD
    256 MB SD RAM
    54X CD ROM
    8X432 Acer CDRW
    This is an assembeled PC
  18. 2002/04/03
    mukundh
    guys............. help pls
  19. 2002/04/03
    Rancher
    Rancher Inactive
    install xp
    Sorry dude, they moved your post to page two. Ah ya know what? Lets see if you can install Win98 on this drive. That would tell us if the winxp cd was maybe bad. You have done this before I know. You don't have a bios overlay I'm sure, so keep us posted on this ok? Your system is not that old & should work just fine.:)
  20. 2002/04/06
    aziefel
    aziefel Inactive
    You want to do it the easy way?
    You should post your Video card and Mother Board type.
    But possibly one or the other isnt on microsoft HCL (Hardware Compatability List). What ever the Case may be an easy work around is get and old video card and install it with that in your computer. Also you probly wiil have to upgrade BIOS. You'll probly end up doing both
    uprgrading your BIOS under Win98 wiill be easier.:eek:
  21. 2002/04/06
    mukundh
    windows 98 works on the computer..
    i removed all my partitions and created new partition and formatted it. stil the same problem...
