install scanner problems
Discussion in 'PC Hardware' started by csnudelman, 2002/04/29.
  1. 2002/04/29
    csnudelman
    csnudelman Inactive Thread Starter
    27th April 2002 17:39
    Offline
    csnudelman []
    Member
    Experience: intermediate
    "Add New Hardware Wizard "
    In tring to make a new reinstall for a scanner the folks at Epson gave me some instructions after which they said the "ADD NEW
    HARDWARE WIZARE" should come up. It didn't. They said to try another "USB" port and that it should come up. It didn't. Is there some way to get this wizard up via another means?
    IP: Logged
    27th April 2002 17:42
    Offline
    holyhandgrenade []
    Member
    Experience: What day is it?
    Settings | Control Panel | Add/Remove Hardware
    __________________
    Then did he raise on high the Holy Hand Grenade of Antioch, saying "Bless this, O Lord, that with it thou mayst blow thine enemies to tiny bits, in thy mercy. "
    IP: Logged
    28th April 2002 10:27
    Offline
    csnudelman []
    Member
    "Add New Hardware Wizard" part 2
    I can't seem to find my CD for 'Windows 98SE'. Is there another way I can get a driver so as to install a scanner?
    IP: Logged
    28th April
    2002 10:43
    Offline
    luqa []
    Senior Member
    Experience: Unconscious!
    Try the Epson web site, and look for the product - support - drivers.
    __________________
    Don't ask the question if you can't accept ALL the answers!
    IP: Logged
    29th April 2002 14:51
    Offline
    csnudelman []
    Member
    I have downloaded the 4 drivers at Epson.com for my 1200U Photo scanner that are for Win 98SE. They are; Twain Driver v4.2;
    Twain Driver v5.53A; Perfection 1200 USB & SCSI Windows 98 INF File & Epson Scan! II 32 Utility v2.35E for Windows 95/98/ 2000/NT 4.0 (With Service Pack 3 or higher). I have gone to the 'install new hardware' but when I reach a certain point Windows can't seem to find the scanner. Advise?
    IP: Logged
  2. 2002/04/29
    luqa
    luqa Inactive
    Hey, *noodles*, are you trying to make some kind of point by repeating the contents of your thread in the Win98 forum? :rolleyes:
    luqa,
    csnudelman
    no, just thought that perhaps someone that reads 'Hardware' but not 'Windows 98' might be able to help.
  5. 2002/05/03
    shawdaifu
    shawdaifu Inactive
    EPSON SCANNER INSTALLATION
    Not sure whether my experience is the same, but I did have problems with my recent installation of Epson Perfection 1250. Do you have their installation disk? They made a big point that software had to be installed before the scanner is hooked up. Perhaps that was why Windows couldn't find it. For some software problems, you may need to contact the software people directly. That info was provided in my users guide. If you do not have that, Epson should be able to give you the name and number. I did have to install a later version of the copy utility drivers than was provided with the scanner. What fixes are necessary are posted on the epson support site.
    My experience--good scanner. You have to beta test the software.
  6. 2002/05/07
    csnudelman
    luqa
    OK, I just read one should not place the same question in two places. What is a senior member?
