Resolved Inno3D GeForce FX 5500 Problem
Discussion in 'PC Hardware' started by NowhereMan, 2010/05/14.
  1. 2010/05/14
    NowhereMan
    NowhereMan Inactive Thread Starter
    I just bought an Inno3D GeForce FX 5500 a few hours ago. The guy working on it seated the thing on my PC, installed the drivers, all that routine stuff.
    When I got home, I tried it and it seems that when I open applications, including Test DirectDraw and Test Direct 3D (DXDIAG), the system crashes!
    It also crashes when I open games (Virtual Sailor) and even when using the nVIDIA Control Panel.
    What should I do?
  2. 2010/05/14
    Under the circumstances you describe I would head straight back to the shop.
    Was the card tested in your computer before you left?
    NowhereMan
    No, no lemme rephrase that: The system *FREEZES*. Sorry, I was getting frustrated...
    Anyway, yes, they tested it but they did not open games and other apps.
  5. 2010/05/14
    NowhereMan
    I'll try the DirectX one first.
    If nothin' happens, I'll try to use the second one.
    Will keep you updated. =)
  7. 2010/05/14
    NowhereMan
    Tried both. No luck.
  8. 2010/05/14
    If you had no problems prior to changing the graphics card I suspect the card itself - either faulty or not compatible.
  9. 2010/05/14
    NowhereMan
    Okay.
    I'll try to contact the seller tomorrow (it's already late night here).
  10. 2010/05/14
    NowhereMan
    It seems that the problem is already solved.
    The problem was the VIA motherboard, so I downloaded the Hyperion driver and poof, the whole thing worked!
    Thanks for the replies. Marking thread as RESOLVED.
  11. 2010/05/15
    Well done - an excellent piece of problem solving :)
