Resolved Info on Defender.
Discussion in 'Security and Privacy' started by BobbyScot, 2015/02/15.
  1. 2015/02/15
    BobbyScot
    Is Defender an upgrade to MES. IS Defender a Malware/Spy Catcher only or does it include Antivirus protection. I realise that MES and Defender can not be installed together. In Windows 8.1. apparently Defender is the default antivirus protection.
  2. 2015/02/15
    Here's the info you require .....
    What is Windows Defender?
  5. 2015/02/15
    BobbyScot
    Thank you for clarifying what appeared to be misleading. Defender only works with Windows 8/8.1. as Antivirus.
  6. 2015/02/15
    No Bobby - read the quote I posted ......
  7. 2015/02/15
    BobbyScot
    Sorry for not reading your quote properly. It certainly appears not to work in Windows 7 and Vista as Antivirus, or I am reading incorrectly again? Thanks Bobby.
  8. 2015/02/15
    Windows Defender is built into Windows 8 - it is not compatible with Windows 7 or Vista, for those OS's Microsoft's offering is Microsoft Security Essentials See the link for a comparison between Defender & MSE.
  9. 2015/02/15
    BobbyScot
    Thanks.
