Incomplete Control Panel in WindowsXP (Home)
Discussion in 'Windows XP' started by donharmon, 2002/03/21.
  1. 2002/03/21
    donharmon
    donharmon Guest Thread Starter
    In attempting to set performance tabs, (virtual memory) I find that my control panel offers no such choices. I think that in the past I selected some "view" of WindowsXP that does not present this.
    I am logged on as an administrator and have only one log-on anyway, so that isn't my problem.
    Any clues for me?
  2. 2002/03/21
    Kevin Lifetime Subscription
    Kevin Well-Known Member
    In XP Pro (Category view), it's:
    Control Panel > Performance and Maintenance > System > Advanced > Performance...Settings > Advanced > Virtual Memory
    In the "Classic" view, go straight to System.
    Rod
    Rod Well-Known Member
    The procedures outlined in Kevin's post works the same in XP Home. You can also access this by in XP Home by right clicking on My Computer, select Properties from the pop-up menu. When System Properties opens click on the Advance tab and then click on the Settings button under Performance. When Performance Options opens click on the Advanced Tab and then the Change button in the Virtual Memory area of the page.
    Home this helps. :)
    Rod,
    richmusick
    richmusick Inactive
    try the windowsKey + Pause/BreakKey opens systems
    properties in one press of the keys.
