Inbox problem in NS 4.8
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by emaloney, 2003/03/01.
  1. 2003/03/01
    emaloney
    emaloney Inactive Thread Starter
    1. I solved two problems by following the instructions that I found in the forum, but now I have one for which I can find no answer. I had the problem, of the Inbox refusing to open. As found, I went to Attributes and unchecked Read Only. Now my Inbox will open and I can get new messages. But Inbox does not open with the messages previously received. I feel sure that they are still there as the file still shows a size of 263 MB. Other files, such as Sent, open normally and show all past messages not deleted - the only problem is with Inbox.
    2. Help, please! I need my file of old incoming messages. Thanks, Mack
  2. 2003/03/01
    Ramona
    Ramona Geek Member Alumni
    Welcome to the Forum,
    Hi Mack,
    Try this:
    Close Netscape
    Open Windows Explorer
    Browse to the
    C:\Program Files\Netscape\Users\yourusername\Mail folder
    Delete the Inbox.snm file
    Open Netscape and see if all of your messages are now accessible.
    Post back if you continue to have problems.
    Ramona :D
    emaloney
    Inbox problem with NS 4.8
    Many thanks, Romona, but it didn't work. No change in the problem.
  5. 2003/03/01
    Ramona
    Hi Mack,
    What you can do, is recreate your Inbox.
    Close Netscape
    Browse to your Users\username\Mail Folder
    Rename your Inbox file (with NO SNM Extension) OLDInbox
    Open Netscape Messenger, and a new Inbox will be created.
    Close Netscape
    Open the Mail Folder
    Open both the newly created Inbox (NO SNM Extension) and the OLDInbox (NO SNM Extension)
    Copy the entire contents of the OLDInbox
    Paste the entire contents of OLDInbox into the newly created Inbox
    If no joy, post back...
    Ramona :D
  6. 2003/03/04
    emaloney
    Thanks again, Ramona, for your patience with me
    I have spent several hours trying your latest suggestion, but am running into problems.
    Step 4 - you say "Open both....." Open into what?
    I have tried using Wordpad and MS Word - I get the
    file opened, but when I try to copy it to be pasted, I run into problems - probably due to the very large size of the file = 264 MB. I tried, briefly, to copy and pasted in sections, but didn't get very far that way either. Perhaps I am not "opening" in the correct manner that you intended. Can you please comment and expand on your procedure? Thanks again!
  7. 2003/03/04
    Ramona
    Hi Mack,
    I see your problem, as I just recreated what you are trying to do with a large Mail folder, and indeed it didn't work! I'm at fault for assuming you would know how to do the step. My apology. A Word Processing editor may add formatting to the text and make the situation worse.
    I'm trying to keep you from having to create a new Profile, not the worst thing to do, but better to avoid if possible.
    Try this, with Netscape Closed, and after backing up your Users Folder:
    Make a copy of the Inbox, move it to another location, and rename it Inbox2
    Copy the renamed Inbox2 file back to the Mail Folder
    Rename Inbox to XInbox
    Delete Inbox.snm
    Open Netscape
    Open Messenger
    You should see a new Inbox with no messages
    You should also see Inbox2 with messages (we can only hope)
    Open Inbox2
    Highlight all messages
    Right click
    Select: Copy Message | Inbox
    The Gods willing, your Messages will be there...
    If this works, then you can delete the Inbox2 Folder in Messenger. Once you close Netscape, then make a backup copy of your Users folder, as you will now have a good working Mail Folder. After a few days, without experiencing further problems. you can then delete the XInbox file...
    I can't recreate your problem, as my 4.79 Inbox isn't corrupt, so I can't guarantee that this will work. Usually deleting the Inbox.snm file is the workaround.
    If this doesn't work, then you will need to create a new Profile.
    One other thought, have you run AdAware recently, or SpyBot, or whatever program you use for spyware? This is just to rule out any outside interference.
    Ramona :D
  8. 2003/03/04
    Ramona
    Hi Mack,
    Other things to try, before creating a new Profile:
    Back up the Users folder
    Close Netscape
    Rename NSREG.DAT to NSREG.BAK
    Located in C:\WINDOWS
    Open Netscape.
    Profile Manager will prompt for a new Profile.
    Use the existing Profile Name (same name as you are now using)
    If you have multiple Profiles, they can be restored the same way
    Not sure this will have any effect, but I'm grasping at straws here, as the usual fix isn't working.
    Did you copy a Mail backup from CD, as you said the Inbox was checked "Read Only "? Was curious about this, because if you still have that copy, I'm wondering if you might try moving it again into your Mail Folder.
    Ramona :D
  9. 2003/03/09
    emaloney
    Ramona
    Again many thanks for all your efforts to help me, but I give up! I have renamed files, moved files, re-renamed files, etc., so much that i am dizzy!
    I am missing a 16-day portion of my Inbox, and I will just have to live without it.
    What strikes me as odd are the following figures:
    Sent file 883 messages 101,543,403 bytes
    Inbox file 83 messages 262,411,037 bytes
    It would appear that the Inbox has more messages that show up on the screen. I have no messages earlier than 06 Jan 03, then everything up thru 10
    Feb, then a gap until 27 Feb, then everything after that date!
    Thanks again and all best wishes to you,
