Inactive [InActive] Trojan disabling internet, system recovery, spybot, etc.
Discussion in 'Malware and Virus Removal Archive' started by libertyguy, 2009/04/30.
  1. 2009/04/30
    libertyguy
    libertyguy Inactive Thread Starter
    Okay. Deep breath. I downloaded a file from the internet in a moment of stupidity and now find myself with a nasty bug. The internet started not working, so I ran a full scan through Symantac and found Perflib_Perfdata_24c located at c:\windows\temp and also tmp1.tmp at c:\Documents and Settings\My Name\Local Settings\Temp. Symantac claimed it was removing these files, but did not succeed after reboot. I tried to manually remove the files but got an error message "disc full/not authorized ". In the meantime, the tmp file was spawining other files such as tmp6.tmp, some of which could be deleted and others not. I went to safe mode and ran symantac again which didn't find the viruses, but I went in and manually removed them, which appeared to work until I went back to normal mode. I tried to do a system restore, but it just doesn't respond. I disabled system restore and went back to safe mode and deleted the files, deleted trash, but once again, no luck. I also have been using a program called Unlocker to get rid of the files in regular mode. It deletes some, which come back after reboot, and also claims its going to get rid of some after reboot and does not. This all occurred yesterday. Today I just tried to open my c: drive through My Computer and was told "Widnows cannot find RECYCLER\S-2-5-27-1000020076-1000024302-100019951-536.com' Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search." I think that's everything so far. Here are the logs (I'm on a different computer btw since the internet does not work on mine.)
    DDS (Ver_09-03-16.01) - NTFSx86
    Run by Jesse Maxwell at 12:52:43.84 on Thu 04/30/2009
    Internet Explorer: 8.0.6001.18372
    Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.510.143 [GMT -4:00]
    AV: Symantec AntiVirus Corporate Edition *On-access scanning enabled* (Updated)
    FW: Norton Internet Worm Protection *disabled*
    C:\windows\system32\Ati2evxx.exe
    C:\windows\system32\svchost -k DcomLaunch
    svchost.exe
    C:\windows\System32\svchost.exe -k netsvcs
    C:\windows\system32\svchost.exe -k WudfServiceGroup
    svchost.exe
    svchost.exe
    C:\windows\Explorer.EXE
    C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
    svchost.exe
    C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    C:\Program Files\Symantec AntiVirus\DefWatch.exe
    C:\WINDOWS\eHome\ehRecvr.exe
    C:\WINDOWS\eHome\ehSched.exe
    C:\windows\System32\svchost.exe -k HTTPFilter
    C:\Program Files\Common Files\LightScribe\LSSrvc.exe
    C:\Program Files\OpenCase\OpenCASE Media Agent\MediaAgent.exe
    C:\Program Files\Symantec AntiVirus\SavRoam.exe
    svchost.exe
    C:\windows\system32\svchost.exe -k imgsvc
    C:\Program Files\Symantec AntiVirus\Rtvscan.exe
    C:\Program Files\Viewpoint\Common\ViewpointService.exe
    C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
    C:\WINDOWS\system32\dllhost.exe
    C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    C:\Program Files\HP\QuickPlay\QPService.exe
    C:\Program Files\HPQ\Quick Launch Buttons\EabServr.exe
    C:\Program Files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe
    C:\PROGRA~1\SYMANT~1\VPTray.exe
    C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
    C:\Program Files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe
    C:\PROGRA~1\hpq\Shared\HPQTOA~1.EXE
    C:\Program Files\QuickTime\QTTask.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\Program Files\Unlocker\UnlockerAssistant.exe
    C:\windows\system32\ctfmon.exe
    C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    C:\windows\system32\spoolsv.exe
    F:\dds.scr
    uStart Page = hxxp://www.hotmail.com/
    uSearch Page = hxxp://www.google.com
    uSearch Bar = hxxp://www.google.com/ie
    uInternet Connection Wizard,ShellNext = hxxp://register.hp.com/servlet/WebReg.servlets.ProdReg1Servlet?appID=java_wreg_wreg_genpg&PURCH_DT_MONTH=02&PURCH_DT_DAY=17&PURCH_DT_YEAR=2006&product_name=HP%20Pavilion%20dv5000%20(xx123x#ABA&PROD_SERIAL_ID=HAL2043211&gwCountry=US&language=EN&prodOS=
    uInternet Settings,ProxyOverride = *.local
    mSearchAssistant = hxxp://www.google.com/ie
    uURLSearchHooks: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} -
    BHO: Adobe PDF Reader Link Helper: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelper.dll
    BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll
    BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    TB: {C4069E3A-68F1-403E-B40E-20066696354B} - No File
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    uRun: [SpybotSD TeaTimer] c:\program files\spybot - search & destroy\TeaTimer.exe
    mRun: [SynTPEnh] c:\program files\synaptics\syntp\SynTPEnh.exe
    mRun: [QPService] "c:\program files\hp\quickplay\QPService.exe "
    mRun: [eabconfg.cpl] c:\program files\hpq\quick launch buttons\EabServr.exe /Start
    mRun: [Cpqset] c:\program files\hpq\default settings\cpqset.exe
    mRun: [RecGuard] c:\windows\sminst\RecGuard.exe
    mRun: [hpWirelessAssistant] c:\program files\hpq\hp wireless assistant\HP Wireless Assistant.exe
    mRun: [ccApp] "c:\program files\common files\symantec shared\ccApp.exe "
    mRun: [vptray] c:\progra~1\symant~1\VPTray.exe
    mRun: [ISUSPM Startup] c:\progra~1\common~1\instal~1\update~1\ISUSPM.exe -startup
    mRun: [ISUSScheduler] "c:\program files\common files\installshield\updateservice\issch.exe" -start
    mRun: [HP Software Update] c:\program files\hp\hp software update\HPWuSchd2.exe
    mRun: [SynTPStart] c:\program files\synaptics\syntp\SynTPStart.exe
    mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 8.0\reader\Reader_sl.exe "
    mRun: [Adobe Photo Downloader] "c:\program files\adobe\photoshop album starter edition\3.2\apps\apdproxy.exe "
    mRun: [QuickTime Task] "c:\program files\quicktime\QTTask.exe" -atboottime
    mRun: [Computer Alarm Clock] c:\progra~1\comput~1\cac.exe
    mRun: [iTunesHelper] "c:\program files\itunes\iTunesHelper.exe "
    mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe "
    mRun: [UnlockerAssistant] "c:\program files\unlocker\UnlockerAssistant.exe "
    IE: E&xport to Microsoft Excel - c:\progra~1\micros~4\office10\EXCEL.EXE/3000
    IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
    IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
    DPF: {166B1BCA-3F9C-11CF-8075-444553540000} - hxxp://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
    DPF: {17492023-C23A-453E-A040-C7C580BBF700} - hxxp://download.microsoft.com/download/3/9/8/398422c0-8d3e-40e1-a617-af65a72a0465/LegitCheckControl.cab
    DPF: {1851174C-97BD-4217-A0CC-E908F60D5B7A} - hxxp://h50203.www5.hp.com/HPISWeb/Customer/cabs/HPISDataManager.CAB
    DPF: {1BA7BD5D-2BE1-4C06-A53F-632BD1C003BA} - hxxps://zone.butler.edu/sre/ISBinstaller.cab
    DPF: {233C1507-6A77-46A4-9443-F871F945D258} - hxxp://fpdownload.macromedia.com/get/shockwave/cabs/director/sw.cab
    DPF: {3E68E405-C6DE-49FF-83AE-41EE9F4C36CE} - hxxp://office.microsoft.com/officeupdate/content/opuc3.cab
    DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} - hxxp://gfx2.hotmail.com/mail/w2/resources/MSNPUpld.cab
    DPF: {54BE6B6F-3056-470B-97E1-BB92E051B6C4} - hxxp://h20264.www2.hp.com/ediags/dd/install/HPDriverDiagnosticsxp2k.cab
    DPF: {5C6698D9-7BE4-4122-8EC5-291D84DBD4A0} - hxxp://upload.facebook.com/controls/FacebookPhotoUploader3.cab
    DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} - hxxp://cdn.scan.onecare.live.com/resource/download/scanner/wlscbase9563.cab
    DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} - hxxp://download.divx.com/webplayer/stage6/windows/DivXBrowserPlugin.cab
    DPF: {6B75345B-AA36-438A-BBE6-4078B4C6984D} - hxxp://h20270.www2.hp.com/ediags/gmn2/install/HPProductDetection.cab
    DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - hxxp://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1147213602117
    DPF: {6F15128C-E66A-490C-B848-5000B5ABEEAC} - hxxps://h20436.www2.hp.com/ediags/dex/secure/HPDEXAXO.cab
    DPF: {7F8C8173-AD80-4807-AA75-5672F22B4582} - hxxps://zone.butler.edu/sre/ICSScanner.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab
    DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/ultrashim.cab
    DPF: {9600F64D-755F-11D4-A47F-0001023E6D5A} - hxxp://web1.shutterfly.com/downloads/Uploader.cab
    DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.5.0/jinstall-1_5_0_06-windows-i586.cab
    DPF: {CAFEEFAC-0015-0000-0009-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.5.0/jinstall-1_5_0_09-windows-i586.cab
    DPF: {CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.5.0/jinstall-1_5_0_10-windows-i586.cab
    DPF: {CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.5.0/jinstall-1_5_0_11-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_01-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_02-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_03-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_05-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_07-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab
    DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - hxxp://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
    DPF: {D821DC4A-0814-435E-9820-661C543A4679} - hxxp://drmlicense.one.microsoft.com/crlupdate/en/crlocx.ocx
    TCP: NameServer = 85.255.0.0,85.255.0.0
    TCP: {1BDFDC2F-A173-4EE1-97C7-AB5140F0B2A0} = 85.255.0.0,85.255.0.0
    Notify: AtiExtEvent - Ati2evxx.dll
    Notify: NavLogon - c:\windows\system32\NavLogon.dll
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    SEH: Windows Desktop Search Namespace Manager: {56f9679e-7826-4c84-81f3-532071a8bcc5} - c:\program files\windows desktop search\MSNLNamespaceMgr.dll
    R1 SAVRT;SAVRT;c:\program files\symantec antivirus\savrt.sys [2005-12-19 337592]
    R1 SAVRTPEL;SAVRTPEL;c:\program files\symantec antivirus\Savrtpel.sys [2005-12-19 54968]
    R2 ccEvtMgr;Symantec Event Manager;c:\program files\common files\symantec shared\ccEvtMgr.exe [2006-3-24 192160]
    R2 ccSetMgr;Symantec Settings Manager;c:\program files\common files\symantec shared\ccSetMgr.exe [2006-3-24 169632]
    R2 McrdSvc;Media Center Extender Service;c:\windows\ehome\mcrdsvc.exe [2005-8-6 99328]
    R2 OpenCASE Media Agent;OpenCASE Media Agent;c:\program files\opencase\opencase media agent\MediaAgent.exe [2008-8-29 835208]
    R2 SavRoam;SAVRoam;c:\program files\symantec antivirus\SavRoam.exe [2006-6-15 115952]
    R2 Symantec AntiVirus;Symantec AntiVirus;c:\program files\symantec antivirus\Rtvscan.exe [2006-6-15 1805552]
    R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\viewpoint\common\ViewpointService.exe [2007-10-10 24652]
    R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\common files\symantec shared\eengine\EraserUtilRebootDrv.sys [2009-2-26 101936]
    R3 HSFHWATI;HSFHWATI;c:\windows\system32\drivers\HSFHWATI.sys [2005-8-22 231424]
    R3 NAVENG;NAVENG;c:\progra~1\common~1\symant~1\virusd~1\20090428.003\naveng.sys [2009-4-28 89104]
    R3 NAVEX15;NAVEX15;c:\progra~1\common~1\symant~1\virusd~1\20090428.003\navex15.sys [2009-4-28 876144]
    S2 pciinfo;HP Pci Information;\??\c:\docume~1\jessem~1\locals~1\temp\hpispz\hpdom\pciinfo.sys --> c:\docume~1\jessem~1\locals~1\temp\hpispz\hpdom\pciinfo.sys [?]
    2009-04-29 17:18 <DIR> --d----- c:\program files\Unlocker
    2009-04-28 21:31 368 -c-shr-- C:\autorun.inf
    2009-04-24 08:31 73,728 a------- c:\windows\system32\javacpl.cpl
    2009-04-22 15:57 <DIR> --d----- c:\program files\common files\DivX Shared
    2009-04-16 13:22 284,160 -------- c:\windows\system32\dllcache\pdh.dll
    2009-04-16 13:22 401,408 -------- c:\windows\system32\dllcache\rpcss.dll
    2009-04-16 13:22 473,600 -------- c:\windows\system32\dllcache\fastprox.dll
    2009-04-16 13:22 110,592 -------- c:\windows\system32\dllcache\services.exe
    2009-04-16 13:22 453,120 -------- c:\windows\system32\dllcache\wmiprvsd.dll
    2009-04-16 13:22 227,840 -------- c:\windows\system32\dllcache\wmiprvse.exe
    2009-04-16 13:22 729,088 -------- c:\windows\system32\dllcache\lsasrv.dll
    2009-04-16 13:22 617,472 -------- c:\windows\system32\dllcache\advapi32.dll
    2009-04-16 13:22 714,752 -------- c:\windows\system32\dllcache\ntdll.dll
    2009-04-16 13:11 2,560 -------- c:\windows\system32\xpsp4res.dll
    2009-04-16 13:11 215,552 -------- c:\windows\system32\dllcache\wordpad.exe
    2009-04-07 21:56 <DIR> --d----- c:\program files\iPod
    2009-04-07 21:54 <DIR> --d----- c:\docume~1\alluse~1\applic~1\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
    2009-04-01 23:02 <DIR> --d----- c:\program files\ETS
    2009-03-31 12:58 1,089,593 -------- c:\windows\system32\dllcache\ntprint.cat
    2009-04-13 00:34 97,159 a------- c:\windows\pchealth\helpctr\offlinecache\index.dat
    2009-03-21 10:06 989,696 -------- c:\windows\system32\dllcache\kernel32.dll
    2009-03-19 16:32 23,400 a------- c:\windows\system32\drivers\GEARAspiWDM.sys
    2009-03-09 05:19 410,984 a------- c:\windows\system32\deploytk.dll
    2009-03-06 10:22 284,160 a------- c:\windows\system32\pdh.dll
    2009-02-09 08:10 729,088 a------- c:\windows\system32\lsasrv.dll
    2009-02-09 08:10 714,752 a------- c:\windows\system32\ntdll.dll
    2009-02-09 08:10 617,472 a------- c:\windows\system32\advapi32.dll
    2009-02-09 08:10 401,408 a------- c:\windows\system32\rpcss.dll
    2009-02-09 07:13 1,846,784 a------- c:\windows\system32\win32k.sys
    2009-02-09 07:13 1,846,784 -------- c:\windows\system32\dllcache\win32k.sys
    2009-02-07 19:02 2,066,048 a------- c:\windows\system32\ntkrnlpa.exe
    2009-02-07 19:02 2,066,048 -------- c:\windows\system32\dllcache\ntkrnlpa.exe
    2009-02-06 07:11 110,592 a------- c:\windows\system32\services.exe
    2009-02-06 07:08 2,189,056 a------- c:\windows\system32\ntoskrnl.exe
    2009-02-06 07:08 2,189,056 -------- c:\windows\system32\dllcache\ntoskrnl.exe
    2009-02-06 07:06 2,145,280 -------- c:\windows\system32\dllcache\ntkrnlmp.exe
    2009-02-06 06:39 35,328 a------- c:\windows\system32\sc.exe
    2009-02-06 06:39 35,328 a------- c:\windows\system32\dllcache\sc.exe
    2009-02-06 06:32 2,023,936 -------- c:\windows\system32\dllcache\ntkrpamp.exe
    2009-02-03 15:59 56,832 a------- c:\windows\system32\secur32.dll
    2009-02-03 15:59 56,832 -------- c:\windows\system32\dllcache\secur32.dll
    2008-09-22 00:04 87,168 ac------ c:\docume~1\jessem~1\applic~1\GDIPFONTCACHEV1.DAT
    2007-06-26 03:59 304 a------- c:\docume~1\jessem~1\applic~1\wklnhst.dat
    2007-06-26 16:09 80 ---shr-- c:\windows\system32\627A8FF6D6.dll
    2008-09-15 10:29 32,768 ac-sh--- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008091520080916\index.dat
    ============= FINISH: 12:53:49.12 ===============
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume1
    Install Date: 5/10/2006 1:50:57 AM
    System Uptime: 4/30/2009 12:24:16 PM (0 hours ago)
    Motherboard: Hewlett-Packard | | 30A4
    Processor: AMD Turion(tm) 64 Mobile Technology ML-32 | U23 | 1790/mhz
    ==== Disk Partitions =========================
    C: is FIXED (NTFS) - 61 GiB total, 13.046 GiB free.
    D: is FIXED (FAT32) - 12 GiB total, 0.253 GiB free.
    E: is CDROM ()
    F: is FIXED (FAT32) - 112 GiB total, 64.482 GiB free.
    ==== Disabled Device Manager Items =============
    Class GUID: {4D36E972-E325-11CE-BFC1-08002BE10318}
    Description: 1394 Net Adapter
    Device ID: V1394\NIC1394\2FA5407D643F0200
    Manufacturer: Microsoft
    Name: 1394 Net Adapter
    PNP Device ID: V1394\NIC1394\2FA5407D643F0200
    Service: NIC1394
    Description: Realtek RTL8139/810x Family Fast Ethernet NIC
    Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_30A4103C&REV_10\4&13826118&1&30A4
    Manufacturer: Realtek Semiconductor Corp.
    Name: Realtek RTL8139/810x Family Fast Ethernet NIC
    PNP Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_30A4103C&REV_10\4&13826118&1&30A4
    Service: RTL8023xp
    Description: Hamachi Network Interface
    Device ID: ROOT\NET\0000
    Manufacturer: LogMeIn, Inc.
    Name: Hamachi Network Interface
    PNP Device ID: ROOT\NET\0000
    Service: hamachi
    ==== System Restore Points ===================
    No restore point in system.
    ==== Installed Programs ======================
    Adobe Flash Player 10 Plugin
    Adobe Flash Player ActiveX
    Adobe Reader 8.1.4
    Adobe Shockwave Player 11
    Adobe® Photoshop® Album Starter Edition 3.2
    AIM 6
    Apple Mobile Device Support
    Apple Software Update
    Athlon 64 Processor Driver
    ATI - Software Uninstall Utility
    ATI Control Panel
    ATI Display Driver
    AviSynth 2.5
    Bonjour
    BufferChm
    CCleaner (remove only)
    Colorizer 1.0.0.1
    Compatibility Pack for the 2007 Office system
    Conexant AC-Link Audio
    CP_AtenaShokunin1Config
    CP_CalendarTemplates1
    cp_LightScribeConfig
    cp_OnlineProjectsConfig
    CP_Package_Basic1
    CP_Package_Variety1
    CP_Package_Variety2
    CP_Package_Variety3
    CP_Panorama1Config
    cp_PosterPrintConfig
    cp_UpdateProjectsConfig
    Critical Update for Windows Media Player 11 (KB959772)
    CueTour
    Customer Experience Enhancement
    DAO
    Destinations
    DeviceManagementQFolder
    DivX Web Player
    FullDPAppQFolder
    Google Chrome
    GRE POWERPREP
    Hauppauge WinTV2000
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
    Hotfix for Windows Internet Explorer 7 (KB947864)
    Hotfix for Windows Media Format 11 SDK (KB929399)
    Hotfix for Windows Media Player 10 (KB903157)
    Hotfix for Windows Media Player 11 (KB939683)
    Hotfix for Windows XP (KB915800-v4)
    Hotfix for Windows XP (KB952287)
    Hotfix for Windows XP (KB954550-v5)
    Hotfix for Windows XP (KB961118)
    HP Deskjet 3740 Series
    HP Driver Diagnostics
    HP Help and Support
    HP Imaging Device Functions 6.0
    HP Photosmart Premier Software 6.0
    HP Product Detection
    HP QuickPlay 2.0
    HP Update
    HP User Guides--System Recovery
    HP User Guides 0025
    HP Wireless Assistant 2.00 C1
    HpSdpAppCoreApp
    InstantShareDevices
    iTunes
    J2SE Runtime Environment 5.0 Update 10
    J2SE Runtime Environment 5.0 Update 11
    J2SE Runtime Environment 5.0 Update 6
    J2SE Runtime Environment 5.0 Update 9
    Japanese Fonts Support For Adobe Reader 8
    Java(TM) 6 Update 13
    Java(TM) 6 Update 2
    Java(TM) 6 Update 3
    Java(TM) 6 Update 5
    Java(TM) 6 Update 7
    Java(TM) SE Runtime Environment 6 Update 1
    LG USB Drivers
    LightScribe 1.4.136.1
    LimeWire 5.1.2
    LiveUpdate 3.0 (Symantec Corporation)
    Microsoft .NET Framework 1.1
    Microsoft .NET Framework 1.1 Hotfix (KB928366)
    Microsoft .NET Framework 2.0 Service Pack 2
    Microsoft .NET Framework 3.0 Service Pack 2
    Microsoft Base Smart Card Cryptographic Service Provider Package
    Microsoft Bootvis
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft Internationalized Domain Names Mitigation APIs
    Microsoft Money 2006
    Microsoft National Language Support Downlevel APIs
    Microsoft Office Live Add-in 1.3
    Microsoft Office XP Media Content
    Microsoft Office XP Standard for Students and Teachers
    Microsoft Silverlight
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Windows XP Video Decoder Checkup Utility
    Microsoft Works
    Move Networks Media Player for Internet Explorer
    MSXML 4.0 SP2 (KB925672)
    MSXML 4.0 SP2 (KB927978)
    MSXML 4.0 SP2 (KB936181)
    MSXML 4.0 SP2 (KB954430)
    muvee autoProducer 4.5
    Norton PC Checkup
    NTI Shadow 3
    Office 2003 Trial Assistant
    OptionalContentQFolder
    PhotoGallery
    Quick Launch Buttons 5.20 F2
    Quicken 2006
    QuickTime
    RandMap
    RealPlayer
    Rhapsody Player Engine
    Security Update for CAPICOM (KB931906)
    Security Update for Step By Step Interactive Training (KB898458)
    Security Update for Step By Step Interactive Training (KB923723)
    Security Update for Windows Internet Explorer 7 (KB928090)
    Security Update for Windows Internet Explorer 7 (KB929969)
    Security Update for Windows Internet Explorer 7 (KB931768)
    Security Update for Windows Internet Explorer 7 (KB933566)
    Security Update for Windows Internet Explorer 7 (KB937143)
    Security Update for Windows Internet Explorer 7 (KB938127)
    Security Update for Windows Internet Explorer 7 (KB939653)
    Security Update for Windows Internet Explorer 7 (KB942615)
    Security Update for Windows Internet Explorer 7 (KB944533)
    Security Update for Windows Internet Explorer 7 (KB950759)
    Security Update for Windows Internet Explorer 7 (KB953838)
    Security Update for Windows Internet Explorer 7 (KB956390)
    Security Update for Windows Internet Explorer 7 (KB958215)
    Security Update for Windows Internet Explorer 7 (KB960714)
    Security Update for Windows Internet Explorer 7 (KB961260)
    Security Update for Windows Media Encoder (KB954156)
    Security Update for Windows Media Player (KB952069)
    Security Update for Windows Media Player 10 (KB911565)
    Security Update for Windows Media Player 10 (KB917734)
    Security Update for Windows Media Player 11 (KB936782)
    Security Update for Windows Media Player 11 (KB954154)
    Security Update for Windows Media Player 6.4 (KB925398)
    Security Update for Windows XP (KB923561)
    Security Update for Windows XP (KB923689)
    Security Update for Windows XP (KB938464-v2)
    Security Update for Windows XP (KB938464)
    Security Update for Windows XP (KB941569)
    Security Update for Windows XP (KB946648)
    Security Update for Windows XP (KB950760)
    Security Update for Windows XP (KB950762)
    Security Update for Windows XP (KB950974)
    Security Update for Windows XP (KB951066)
    Security Update for Windows XP (KB951376-v2)
    Security Update for Windows XP (KB951376)
    Security Update for Windows XP (KB951698)
    Security Update for Windows XP (KB951748)
    Security Update for Windows XP (KB952004)
    Security Update for Windows XP (KB952954)
    Security Update for Windows XP (KB953839)
    Security Update for Windows XP (KB954211)
    Security Update for Windows XP (KB954459)
    Security Update for Windows XP (KB954600)
    Security Update for Windows XP (KB955069)
    Security Update for Windows XP (KB956391)
    Security Update for Windows XP (KB956572)
    Security Update for Windows XP (KB956802)
    Security Update for Windows XP (KB956803)
    Security Update for Windows XP (KB956841)
    Security Update for Windows XP (KB957095)
    Security Update for Windows XP (KB957097)
    Security Update for Windows XP (KB958644)
    Security Update for Windows XP (KB958687)
    Security Update for Windows XP (KB958690)
    Security Update for Windows XP (KB959426)
    Security Update for Windows XP (KB960225)
    Security Update for Windows XP (KB960715)
    Security Update for Windows XP (KB960803)
    Security Update for Windows XP (KB961373)
    SkinsHP1
    Soft Data Fax Modem with SmartCP
    Sonic Audio Module
    Sonic Copy Module
    Sonic Data Module
    Sonic Express Labeler
    Sonic MyDVD Plus
    Sonic Update Manager
    Sonic_PrimoSDK
    SonicAC3Encoder
    SonicMPEGEncoder
    Spybot - Search & Destroy 1.5.2.20
    Symantec AntiVirus
    Synaptics Pointing Device Driver
    Texas Instruments PCIxx21/x515/xx12 drivers.
    TIPCI
    TitanTV Client components for ATI
    TourSetup
    Unload
    Unlocker 1.8.7
    Update for Windows Internet Explorer 8 (KB961813)
    Update for Windows Media Player 10 (KB913800)
    Update for Windows Media Player 10 (KB926251)
    Update for Windows XP (KB943729)
    Update for Windows XP (KB951072-v2)
    Update for Windows XP (KB951978)
    Update for Windows XP (KB955839)
    Update for Windows XP (KB967715)
    Update Rollup 2 for Windows XP Media Center Edition 2005
    VC80CRTRedist - 8.0.50727.762
    VideoLAN VLC media player 0.8.6b
    Viewpoint Media Player
    WebFldrs XP
    WinAce Archiver
    Winamp
    Windows Genuine Advantage Notifications (KB905474)
    Windows Genuine Advantage Validation Tool (KB892130)
    Windows Internet Explorer 8 Release Candidate 1
    Windows Live OneCare safety scanner
    Windows Live Sign-in Assistant
    Windows Media Connect
    Windows Media Encoder 9 Series
    Windows Media Format 11 runtime
    Windows Search 4.0
    Windows XP Media Center Edition 2005 KB925766
    Windows XP Service Pack 3
    WinRAR archiver
    Wireless Home Network Setup
    Xiph QuickTime Components
    Xvid 1.1.3 final uninstall
    ==== Event Viewer Messages From Past Week ========
    4/29/2009 9:26:53 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AmdK8 eabfiltr eeCtrl Fips SAVRT SAVRTPEL SPBBCDrv SYMTDI
    4/29/2009 7:13:00 AM, error: Schedule [7901] - The At1.job command failed to start due to the following error: General access denied error
    4/29/2009 6:52:26 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service wuauserv with arguments " " in order to run the server: {E60687F7-01A1-40AA-86AC-DB1CBF673334}
    4/29/2009 5:51:40 PM, error: Service Control Manager [7034] - The Java Quick Starter service terminated unexpectedly. It has done this 1 time(s).
    4/29/2009 4:47:39 PM, error: sr [1] - The System Restore filter encountered the unexpected error '0xC0000001' while processing the file '' on the volume 'HarddiskVolume4'. It has stopped monitoring the volume.
    4/29/2009 3:33:17 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service StiSvc with arguments " " in order to run the server: {A1F4E726-8CF1-11D1-BF92-0060081ED811}
    4/29/2009 3:32:56 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service netman with arguments " " in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
    4/29/2009 3:32:47 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AFD AmdK8 eabfiltr eeCtrl Fips IPSec MRxSmb NetBIOS NetBT RasAcd Rdbss SAVRT SAVRTPEL SPBBCDrv SYMTDI Tcpip
    4/29/2009 3:32:47 PM, error: Service Control Manager [7001] - The TCP/IP NetBIOS Helper service depends on the AFD service which failed to start because of the following error: A device attached to the system is not functioning.
    4/29/2009 3:32:47 PM, error: Service Control Manager [7001] - The IPSEC Services service depends on the IPSEC driver service which failed to start because of the following error: A device attached to the system is not functioning.
    4/29/2009 3:32:47 PM, error: Service Control Manager [7001] - The DNS Client service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
    4/29/2009 3:32:47 PM, error: Service Control Manager [7001] - The DHCP Client service depends on the NetBios over Tcpip service which failed to start because of the following error: A device attached to the system is not functioning.
    4/29/2009 3:32:47 PM, error: Service Control Manager [7001] - The Bonjour Service service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
    4/29/2009 3:32:47 PM, error: Service Control Manager [7001] - The Apple Mobile Device service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
    4/29/2009 3:32:40 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments " " in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
    4/28/2009 9:39:07 PM, error: Service Control Manager [7031] - The Symantec AntiVirus service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
    4/28/2009 11:46:42 PM, error: Service Control Manager [7034] - The Application Layer Gateway Service service terminated unexpectedly. It has done this 1 time(s).
    4/28/2009 11:26:56 PM, error: sr [1] - The System Restore filter encountered the unexpected error '0xC0000001' while processing the file '' on the volume 'HarddiskVolume2'. It has stopped monitoring the volume.
    4/28/2009 11:11:02 PM, error: Service Control Manager [7024] - The Windows Search service terminated with service-specific error 2147749155 (0x80040D23).
    4/28/2009 11:10:48 PM, error: Service Control Manager [7000] - The HP Pci Information service failed to start due to the following error: The system cannot find the path specified.
    4/27/2009 7:30:46 PM, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the stisvc service.
    4/27/2009 7:30:33 PM, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the Dnscache service.
    ==== End Of File ===========================
  2. 2009/05/01
    libertyguy
    Update: I used Autoruns in safe mode and found logonui.exe and deleted it in Autorun, but I couldn't find it on my computer to delete it. Now when I reboot, Windows asks me for a password. In all the years I've had the computer I've never entered a password. Is this the virus or something I could have caused? Is it possible I entered a password long ago and have never been prompted to use it until now for some reason? I've tried my usual list of passwords and none have worked.
    registerthis
    registerthis Inactive
    No password
    Just a thought, did you try no password? Just type the enter key in the password field. If you never entered a password then it should be nothing.
  5. 2009/05/01
    libertyguy
    Thanks! Your suggestion worked. Unfortunately, my computer still seems to be in the same state it was in, if not worse. When I got into Windows my firewall and symantac were both turned off (not by me) though I think they're back on now. This thing is evil...
  6. 2009/05/02
    libertyguy
    Processes running
    I used a database to look up some of the more questionable processes in my task manager. I know some of these might be benign parts of my computer, but they all were listed as having possible malicious doppelgangers. Hope this helps.
    VPC32.EXE
    Ctfmon.exe
    jusched.exe
    QTTask.exe
    Vptray.exe
    ccApp.exe
    dlhost.exe
    S-7-7-95-100008823-1000028809-100000382-6931.com (didn't find this one in the database. I just assumed.)
    rundll32.exe
    alg.exe
    svchost.exe (this one appears multiple times)
    ehSched.exe
    Services.exe
    Also, on my Toshiba external drive, which was unfortunately hooked up at the time of infection, I found Wn32\Alureon!inf. in a seperate scan.
    Thanks in advance for any help I can receive!
  7. 2009/05/10
    Juliet
    Juliet Well-Known Member
    Hi and welcome
    Save these instructions to wordpad/notepad or print them out, while some of the fix will have all windows closed and will help you complete all the necessary steps.
    Since this computer has no internet access you'll have to Download the tools needed to a flash drive or other removable media, and transfer them to the infected computer.
    Please download SmitfraudFix (by S!Ri) Extract the content (a folder named SmitfraudFix) to your Desktop.
    Double-click on SmitfraudFix.exe to start the tool.
    Select option #3 - Delete Trusted zone by typing 3 and press Enter
    Answer Yes to the question "Restore Trusted Zone ?" by typing Yes and press Enter
    Notes
    1. If you use SpywareBlaster and/or IE-SPYAD it will be necessary to re-install the protection both afford. For SpywareBlaster, run the program and re-protect all items. For IE-SPYAD, run the batch file and reinstall the protection.
    2. As many of the variants of Smitfraud have begun invading the Hosts file, this tool will reset your Hosts file as a necessary precaution. You will also have to reset any specific modifications you may require such as Hosts MVPS.
    NEXT**
    Once again Open the SmitfraudFix folder on your desktop.
    Select option #5 - "Search and Clean DNS Hijack" by typing 5 and pressing "Enter" to delete the rogue settings.
    Follow the prompts and reboot if asked to do so.
    NEXT**
    Please download Malwarebytes' Anti-Malware to your desktop
    Additional Link
    * Double-click mbam-setup.exe and follow the prompts to install the program.
    * Be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
    * If an update is found, it will download and install the latest version.
    * Once the program has loaded, select Perform quick scan, then click Scan.
    * When the scan is complete, click OK, then Show Results to view the results.
    * Be sure that everything is checked, and click Remove Selected.
    * When completed, a log will open in Notepad. Please save it to a convenient location.
    * You can also access the log by doing the following:
    o Click on the Malwarebytes' Anti-Malware icon to launch the program.
    o Click on the Logs tab.
    o Click on the log at the bottom of those listed to highlight it.
    o Click Open.
    Tutorial if needed
    http://thespykiller.co.uk/index.php/topic,5946.0.html
    Extra Note:
    If MBAM encounters a file that is difficult to remove,you will be presented with 1 of 2 prompts,click OK to either and let MBAM proceed with the disinfection process,if asked to restart the computer,please do so immediatly.
    In your next reply post:
    Smitfraud rapport.txt
    Malwarebytes' Anti-Malware log
    New HJT log
