Solved iexplore.exe problem??
Discussion in 'Malware and Virus Removal Archive' started by thecubanboys, 2009/11/22.
  1. 2009/11/22
    thecubanboys
    thecubanboys Inactive Thread Starter
    [Resolved] iexplore.exe problem??
    Hi there,
    I've been bugged the last couple of days with pop ups on firefox. Also when i click on a google search result, instead of opening the page i want to view it opens random pages (ebay, skybet, etc). I get an error appearing every 10mins or so that says that iexplore.exe failed to initialize properly (0xc0000142). I don't use internet explorer but yet it is always running in the process list. When I delete it, it returns within a few seconds. I've read that this is a trojan and was wondering if anyone would be able to help me get rid of it. I've tried the usual Anti-virus, Anti-spyware programs but i'm still having trouble. Ive download and run the dds program as suggested on the forum but it only opens one massive text file unlike the logs i've seen anywhere else :(
    Any help would be much appreciated
    Steven
  2. 2009/11/22
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    2. Close any open browsers.
      • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
      • Double click on combofix.exe & follow the prompts.
      • When finished, it will produce a report for you.
      • Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
      Download HijackThis:
      http://www.trendsecure.com/portal/en-US/tools/security_tools/hijackthis/download
      by clicking on Download HijackThis Installer
      Install, and run it.
      Post HijackTHis log.
      Do NOT attempt to fix anything!
      NOTE. If you're using Vista, right click on HijackThis, and click Run as Administrator
    thecubanboys
    Hi,
    Thanks for the quick reply. I will Post both the logs below
    Steven
    COMBOFIX log
    ComboFix 09-11-22.02 - thecubanboys 22/11/2009 19:55.1.2 - x86
    Microsoft® Windows Vistaâ„¢ Home Premium 6.0.6001.1.1252.44.1033.18.2045.1253 [GMT 0:00]
    Running from: c:\users\thecubanboys\Desktop\ComboFix.exe
    SP: SUPERAntiSpyware *disabled* (Updated) {222A897C-5018-402e-943F-7E7AC8560DA7}
    SP: Windows Defender *disabled* (Updated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
    c:\$recycle.bin\S-1-5-21-1400113804-1914402855-3429530994-500
    c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500
    c:\$recycle.bin\S-1-5-21-4126253998-389922501-3043565072-500
    c:\program files\WinPCap
    c:\program files\WinPCap\rpcapd.exe
    c:\users\thecubanboys\AppData\Roaming\Desktopicon
    c:\users\thecubanboys\AppData\Roaming\Desktopicon\eBay.ico
    c:\users\thecubanboys\AppData\Roaming\Desktopicon\uninst.exe
    c:\users\thecubanboys\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Security Tool.lnk
    c:\windows\system32\drivers\npf.sys
    c:\windows\system32\Packet.dll
    c:\windows\system32\pthreadVC.dll
    c:\windows\system32\wpcap.dll
    Infected copy of c:\windows\system32\drivers\atapi.sys was found and disinfected
    Restored copy from - Kitty ate it :p
    Infected copy of c:\windows\system32\drivers\iastor.sys was found and disinfected
    ((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
    -------\Legacy_NPF
    ((((((((((((((((((((((((( Files Created from 2009-10-22 to 2009-11-22 )))))))))))))))))))))))))))))))
    2009-11-22 20:12 . 2009-11-22 20:15 -------- d-----w- c:\users\thecubanboys\AppData\Local\temp
    2009-11-22 20:12 . 2009-11-22 20:12 -------- d-----w- c:\users\Default\AppData\Local\temp
    2009-11-22 19:48 . 2006-11-02 09:51 232040 ----a-w- c:\windows\system32\drivers\iastorv.sys
    2009-11-22 12:14 . 2009-11-22 12:14 117760 ----a-w- c:\users\thecubanboys\AppData\Roaming\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
    2009-11-22 12:11 . 2009-11-22 12:11 -------- d-----w- c:\programdata\SUPERAntiSpyware.com
    2009-11-22 12:10 . 2009-11-22 12:10 4096 d-----w- c:\program files\SUPERAntiSpyware
    2009-11-22 12:10 . 2009-11-22 12:10 -------- d-----w- c:\users\thecubanboys\AppData\Roaming\SUPERAntiSpyware.com
    2009-11-22 12:10 . 2009-11-22 12:10 -------- d-----w- c:\program files\CCleaner
    2009-11-22 12:09 . 2009-11-22 12:09 -------- d-----w- c:\program files\Marcos Velasco Security
    2009-11-22 12:07 . 2009-11-22 12:07 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
    2009-11-22 11:06 . 2009-11-22 11:06 -------- d-----w- c:\programdata\IObit
    2009-11-22 11:06 . 2009-11-22 11:06 -------- d-----w- c:\program files\IObit
    2009-11-22 10:37 . 2009-11-22 11:00 -------- d-----w- c:\program files\Spyware Doctor
    2009-11-22 10:37 . 2009-11-22 11:00 -------- d-----w- c:\program files\Common Files\PC Tools
    2009-11-20 11:16 . 2009-11-20 15:15 -------- d-----w- c:\users\thecubanboys\AppData\Local\deskmsvcDirect
    2009-11-20 10:02 . 2009-11-20 10:02 -------- d-----w- c:\users\thecubanboys\AppData\Roaming\Malwarebytes
    2009-11-20 10:02 . 2009-09-10 14:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-11-20 10:01 . 2009-11-20 10:01 -------- d-----w- c:\programdata\Malwarebytes
    2009-11-20 10:01 . 2009-09-10 14:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
    2009-11-20 10:01 . 2009-11-20 10:02 4096 d-----w- c:\program files\Malwarebytes' Anti-Malware
    2009-11-19 22:14 . 2009-11-19 22:14 439816 ----a-w- c:\users\thecubanboys\AppData\Roaming\Real\Update\setup3.09\setup.exe
    2009-11-18 09:09 . 2009-11-02 20:42 195456 ------w- c:\windows\system32\MpSigStub.exe
    2009-11-15 17:15 . 2009-11-15 21:42 -------- d-----w- c:\users\thecubanboys\AppData\Roaming\MtStudio
    2009-11-15 17:15 . 2009-11-15 17:16 -------- d-----w- c:\programdata\MtStudio
    2009-11-15 17:15 . 2009-11-15 17:15 4096 d-----w- c:\program files\MtStudio
    2009-11-12 00:12 . 2009-08-14 13:53 2035712 ----a-w- c:\windows\system32\win32k.sys
    2009-11-12 00:12 . 2009-08-10 13:05 351232 ----a-w- c:\windows\system32\WSDApi.dll
    2009-11-11 21:08 . 2009-11-11 21:08 -------- d-----w- c:\program files\Common Files\Skype
    2009-11-11 20:52 . 2009-11-11 20:46 24403616 ----a-w- c:\programdata\Installations\{4C911A61-39EA-41CC-AB3C-FE3BFFDB5F78}\NokiaSoftwareUpdaterSetup_1.8.10EN.exe
    2009-11-11 20:51 . 2009-11-11 20:51 3351812 ----a-w- c:\programdata\Installations\{4C911A61-39EA-41CC-AB3C-FE3BFFDB5F78}\Installer\CommonCustomActions\msxml6Exec.exe
    2009-11-11 20:51 . 2009-11-11 20:51 36864 ----a-w- c:\programdata\Installations\{4C911A61-39EA-41CC-AB3C-FE3BFFDB5F78}\Installer\CommonCustomActions\Sleep.exe
    2009-11-11 20:51 . 2009-11-11 20:51 3203453 ----a-w- c:\programdata\Installations\{4C911A61-39EA-41CC-AB3C-FE3BFFDB5F78}\Installer\CommonCustomActions\vcredistExec.exe
    2009-11-11 20:36 . 2009-11-11 20:36 -------- d-----w- c:\programdata\Nokia
    2009-11-01 20:51 . 2007-10-12 15:14 1374232 ----a-w- c:\windows\system32\D3DCompiler_36.dll
    2009-11-01 20:50 . 2005-05-26 15:34 2297552 ----a-w- c:\windows\system32\d3dx9_26.dll
    2009-10-31 08:30 . 2009-10-31 08:30 4096 d-----w- c:\program files\PowerISO
    2009-10-29 16:17 . 2009-10-29 16:17 4096 d-----w- c:\program files\SSC Service Utility
    2009-10-28 03:58 . 2009-09-10 15:21 310784 ----a-w- c:\windows\system32\unregmp2.exe
    2009-10-28 03:57 . 2009-09-10 15:21 8147456 ----a-w- c:\windows\system32\wmploc.DLL
    2009-10-26 15:06 . 2009-10-26 15:11 -------- d-----w- c:\program files\exPressit SX 3.0
    2009-11-22 20:13 . 2007-12-18 16:37 12 ----a-w- c:\windows\bthservsdp.dat
    2009-11-22 19:41 . 2007-12-18 17:03 4096 d-----w- c:\programdata\McAfee
    2009-11-22 16:36 . 2009-04-22 12:53 -------- d-----w- c:\users\thecubanboys\AppData\Roaming\Spotify
    2009-11-22 16:03 . 2009-01-15 00:50 210080 ----a-w- c:\programdata\nvModes.dat
    2009-11-22 15:50 . 2007-12-20 17:34 123328 ----a-w- c:\users\thecubanboys\AppData\Local\GDIPFONTCACHEV1.DAT
    2009-11-22 10:48 . 2008-11-13 14:38 8268 ----a-w- c:\users\thecubanboys\AppData\Local\d3d9caps.dat
    2009-11-22 10:37 . 2008-11-29 15:14 4096 d-----w- c:\program files\Unlocker
    2009-11-19 10:15 . 2008-03-04 16:12 4096 d-----w- c:\users\thecubanboys\AppData\Roaming\Skype
    2009-11-19 08:05 . 2008-03-04 16:14 20480 d-----w- c:\users\thecubanboys\AppData\Roaming\skypePM
    2009-11-12 03:22 . 2006-11-02 11:18 4096 d-----w- c:\program files\Windows Mail
    2009-11-12 03:06 . 2007-12-21 14:20 8192 d-----w- c:\programdata\Microsoft Help
    2009-11-11 21:09 . 2009-06-19 14:33 -------- d-----r- c:\program files\Skype
    2009-11-11 21:08 . 2008-03-04 16:12 4096 d-----w- c:\programdata\Skype
    2009-11-11 21:06 . 2009-11-11 21:06 0 ---ha-w- c:\windows\system32\drivers\Msft_Kernel_ccdcmb_01007.Wdf
    2009-11-11 20:54 . 2009-03-28 17:58 4096 d-----w- c:\program files\Nokia
    2009-11-11 20:52 . 2009-03-28 18:05 4096 d-----w- c:\program files\Common Files\Nokia
    2009-11-11 20:47 . 2009-03-28 18:09 -------- d-----w- c:\programdata\Installations
    2009-11-09 21:15 . 2007-12-18 16:59 4096 d-----w- c:\programdata\Roxio
    2009-11-01 21:41 . 2008-04-18 20:39 4096 d-----w- c:\program files\Sports Interactive
    2009-11-01 20:54 . 2009-08-16 09:41 4096 d-----w- c:\programdata\Sports Interactive
    2009-11-01 20:53 . 2007-12-21 15:36 4096 d-----w- c:\users\thecubanboys\AppData\Roaming\Sports Interactive
    2009-10-16 02:06 . 2007-12-18 17:07 24576 d-----w- c:\program files\Microsoft Works
    2009-10-11 22:19 . 2009-10-11 22:19 4096 d-----w- c:\program files\Common Files\DVDVideoSoft
    2009-10-11 22:19 . 2009-10-11 22:19 -------- d-----w- c:\program files\DVDVideoSoft
    2009-10-10 09:49 . 2009-10-10 09:49 4096 d-----w- c:\program files\Free Audio Pack
    2009-10-06 11:00 . 2009-09-29 10:48 -------- d-----w- c:\users\thecubanboys\AppData\Roaming\VistaAudio
    2009-10-04 00:22 . 2009-10-04 00:22 4096 d-----w- c:\program files\Microsoft Office Outlook Connector
    2009-10-04 00:21 . 2007-12-21 13:25 4096 d-----w- c:\program files\Windows Live
    2009-09-29 10:48 . 2009-09-29 10:48 4096 d-----w- c:\program files\Vista Audio Changer
    2009-09-14 09:44 . 2009-10-15 09:09 144896 ----a-w- c:\windows\system32\drivers\srv2.sys
    2009-09-10 17:30 . 2009-10-15 09:10 213504 ----a-w- c:\windows\system32\msv1_0.dll
    2009-09-04 12:24 . 2009-10-15 09:09 61440 ----a-w- c:\windows\system32\msasn1.dll
    2009-08-31 13:55 . 2009-10-15 09:09 293376 ----a-w- c:\windows\system32\psisdecd.dll
    2009-08-31 13:55 . 2009-10-15 09:10 428544 ----a-w- c:\windows\system32\EncDec.dll
    2009-08-28 12:39 . 2009-09-02 22:33 28672 ----a-w- c:\windows\system32\Apphlpdm.dll
    2009-08-28 10:15 . 2009-09-02 22:33 4240384 ----a-w- c:\windows\system32\GameUXLegacyGDFs.dll
    2009-08-27 13:32 . 2009-10-15 09:10 833024 ----a-w- c:\windows\system32\wininet.dll
    2009-08-27 13:29 . 2009-10-15 09:10 78336 ----a-w- c:\windows\system32\ieencode.dll
    2009-08-27 10:58 . 2009-10-15 09:10 26624 ----a-w- c:\windows\system32\ieUnatt.exe
    2004-03-15 17:51 . 2004-03-15 17:51 114688 ----a-w- c:\program files\internet explorer\plugins\LV71ActiveXControl.dll
    2006-01-23 10:32 . 2006-01-23 10:32 131072 ----a-w- c:\program files\internet explorer\plugins\LV80ActiveXControl.dll
    2007-02-08 10:48 . 2007-02-08 10:48 133920 ----a-w- c:\program files\internet explorer\plugins\LV82ActiveXControl.dll
    2007-07-24 19:03 . 2007-07-24 19:03 118784 ----a-w- c:\program files\internet explorer\plugins\LV85ActiveXControl.dll
    2007-04-16 23:10 . 2007-12-30 09:35 539136 ----a-w- c:\program files\mozilla firefox\components\pbgk1_8.dll
    2009-02-24 19:34 . 2009-02-24 19:34 1044480 ----a-w- c:\program files\mozilla firefox\plugins\libdivx.dll
    2009-02-24 19:34 . 2009-02-24 19:34 200704 ----a-w- c:\program files\mozilla firefox\plugins\ssldivx.dll
    2007-12-19 00:30 . 2007-12-19 00:19 8192 --sha-w- c:\windows\Users\Default\NTUSER.DAT
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\UEAFOverlay]
    @= "{F2F31467-B1AC-4df0-AE79-FD5FA085E22B} "
    [HKEY_CLASSES_ROOT\CLSID\{F2F31467-B1AC-4df0-AE79-FD5FA085E22B}]
    2007-04-16 23:13 721408 ----a-w- c:\program files\Fingerprint Reader Suite\farchns.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\UEAFOverlayOpen]
    @= "{A3E208F7-0E3A-4182-A7A6-B169D5D691AA} "
    [HKEY_CLASSES_ROOT\CLSID\{A3E208F7-0E3A-4182-A7A6-B169D5D691AA}]
    "ehTray.exe "= "c:\windows\ehome\ehTray.exe" [2008-01-19 125952]
    "msnmsgr "= "c:\program files\Windows Live\Messenger\msnmsgr.exe" [2009-07-26 3883856]
    "Skype "= "c:\program files\Skype\\Phone\Skype.exe" [2009-10-09 25623336]
    "SUPERAntiSpyware "= "c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2009-11-11 2001648]
    "TkBellExe "= "c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-03-30 185896]
    "QuickTime Task "= "c:\program files\QuickTime\QTTask.exe" [2008-03-28 413696]
    "SigmatelSysTrayApp "= "c:\program files\SigmaTel\C-Major Audio\WDM\sttray.exe" [2007-09-07 405504]
    "UnlockerAssistant "= "c:\program files\Unlocker\UnlockerAssistant.exe" [2009-10-26 15872]
    "NvCplDaemon "= "c:\windows\system32\NvCpl.dll" [2008-09-03 13552160]
    "NvMediaCenter "= "c:\windows\system32\NvMcTray.dll" [2008-09-03 92704]
    "NVHotkey "= "c:\windows\system32\nvHotkey.dll" [2008-09-03 96800]
    "Adobe Reader Speed Launcher "= "c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-10-15 39792]
    "AVG8_TRAY "= "c:\progra~1\AVG\AVG8\avgtray.exe" [2009-11-03 2028312]
    "PWRISOVM.EXE "= "c:\program files\PowerISO\PWRISOVM.EXE" [2009-07-27 180224]
    "IObit Security 360 "= "c:\program files\IObit\IObit Security 360\IS360tray.exe" [2009-11-14 1278736]
    c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\
    $McRebootA5E6DEAA56$.lnk - c:\windows\System32\cmd.exe [2008-7-30 318976]
    Logitech SetPoint.lnk - c:\program files\Logitech\SetPoint\SetPoint.exe [2009-3-8 688128]
    Nokia Nseries PC Suite.lnk - c:\program files\Nokia\NNPCS\RunLauncher.exe [2008-5-8 943568]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
    "DisableCAD "= 1 (0x1)
    "EnableUIADesktopToggle "= 0 (0x0)
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2009-09-03 14:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\psfus]
    2007-04-16 23:04 86528 ----a-w- c:\windows\System32\psqlpwd.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
    "AppInit_DLLs "=c:\windows\System32\avgrsstx.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
    "aux3 "=wdmaud.drv
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
    Notification Packages REG_MULTI_SZ scecli psqlpwd
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinDefend]
    @= "Service "
    [HKLM\~\startupfolder\C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Bluetooth.lnk]
    backup=c:\windows\pss\Bluetooth.lnk.CommonStartup
    backupExtension=.CommonStartup
    [HKLM\~\startupfolder\C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^QuickSet.lnk]
    backup=c:\windows\pss\QuickSet.lnk.CommonStartup
    [HKLM\~\startupfolder\C:^Users^thecubanboys^AppData^Roaming^Microsoft^Windows^Start Menu^Programs^Startup^Adobe Gamma.lnk]
    backup=c:\windows\pss\Adobe Gamma.lnk.Startup
    backupExtension=.Startup
    HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\54754126
    HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Google Desktop Search
    HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\kdx
    HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\lphceu8j0er2p
    HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PromoReg
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiSpyware]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Svc]
    "AntiVirusOverride "=dword:00000001
    R0 nipbcfk;National Instruments Class Upper Filter Driver;c:\windows\System32\drivers\nipbcfk.sys [10/07/2007 19:08 15448]
    R1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\System32\drivers\avgldx86.sys [28/03/2009 16:23 335240]
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [11/11/2009 10:44 9968]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [11/11/2009 10:44 74480]
    R2 avg8wd;AVG Free8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [28/03/2009 16:23 297752]
    R2 IS360service;IS360service;c:\program files\IObit\IObit Security 360\is360srv.exe [22/11/2009 11:06 312592]
    R2 nidevldu;NI Device Loader;c:\windows\System32\nipalsm.exe [16/02/2007 10:21 12696]
    R2 nipxirmk;nipxirmk;c:\windows\System32\drivers\nipxirmkl.sys [18/09/2007 07:24 11552]
    R2 NiViPxiK;NI-VISA PXI Driver;c:\windows\System32\drivers\NiViPxiKl.sys [19/07/2007 11:56 11360]
    R3 b57nd60x;Broadcom NetXtreme Gigabit Ethernet - NDIS 6.0;c:\windows\System32\drivers\b57nd60x.sys [19/12/2007 00:30 179712]
    R3 nidimk;nidimk;c:\windows\System32\drivers\nidimkl.sys [14/12/2007 12:41 11360]
    R3 nimru2k;nimru2k;c:\windows\System32\drivers\nimru2kl.sys [14/12/2007 15:06 11360]
    R3 nimstsk;nimstsk;c:\windows\System32\drivers\nimstskl.sys [18/12/2007 18:14 11360]
    R3 OEM04Vfx;Creative Camera OEM004 Video VFX Driver;c:\windows\System32\drivers\OEM04Vfx.sys [19/12/2007 00:30 7424]
    R3 OEM04Vid;Creative Camera OEM004 Driver;c:\windows\System32\drivers\OEM04Vid.sys [19/12/2007 00:30 234560]
    S3 fssfltr;FssFltr;c:\windows\System32\drivers\fssfltr.sys [04/10/2009 00:22 54632]
    S3 fsssvc;Windows Live Family Safety Service;c:\program files\Windows Live\Family Safety\fsssvc.exe [05/08/2009 21:48 704864]
    S3 lvalarmk;lvalarmk;c:\windows\System32\drivers\lvalarmk.sys [20/12/2007 09:37 20056]
    S3 ni1006k;NI PXI-1006 Chassis Pilot;c:\windows\System32\drivers\ni1006k.sys [08/10/2007 14:10 25888]
    S3 ni1045k;NI PXI-1045 Chassis Pilot;c:\windows\System32\drivers\ni1045kl.sys [08/10/2007 14:10 11552]
    S3 ni1065k;NI PXIe-1065 Chassis Pilot;c:\windows\System32\drivers\ni1065k.sys [08/10/2007 14:10 22360]
    S3 nicdrk;nicdrk;c:\windows\System32\drivers\nicdrkl.sys [26/12/2007 11:53 11352]
    S3 nicsrk;nicsrk;c:\windows\System32\drivers\nicsrkl.sys [22/02/2008 11:25 11336]
    S3 nidmxfk;nidmxfk;c:\windows\System32\drivers\nidmxfkl.sys [18/12/2007 18:20 11336]
    S3 nidsark;nidsark;c:\windows\System32\drivers\nidsarkl.sys [15/02/2008 15:37 11344]
    S3 niemrk;niemrk;c:\windows\System32\drivers\niemrkl.sys [22/02/2008 11:25 11336]
    S3 niemrkw;niemrkw;c:\windows\System32\drivers\niemrkw.sys [22/02/2008 11:25 11336]
    S3 niesrk;niesrk;c:\windows\System32\drivers\niesrkl.sys [22/02/2008 11:25 11336]
    S3 nifslk;nifslk;c:\windows\System32\drivers\nifslkl.sys [26/12/2007 11:18 11352]
    S3 nimsdrk;nimsdrk;c:\windows\System32\drivers\nimsdrkl.sys [11/01/2008 16:08 11392]
    S3 nimsrlk;nimsrlk;c:\windows\System32\drivers\nimsrlk.dll [04/04/2007 08:06 151683]
    S3 nimxpk;nimxpk;c:\windows\System32\drivers\nimxpkl.sys [18/12/2007 18:14 11368]
    S3 ninshsdk;ninshsdk;c:\windows\System32\drivers\ninshsdkl.sys [27/12/2007 09:45 11360]
    S3 nipalfwedl;nipalfwedl;c:\windows\System32\drivers\nipalfwedl.sys [12/12/2007 23:23 11904]
    S3 nipalusbedl;nipalusbedl;c:\windows\System32\drivers\nipalusbedl.sys [12/12/2007 23:22 11896]
    S3 nipxigpk;NI PXI Generic Chassis Pilot;c:\windows\System32\drivers\nipxigpk.sys [26/11/2007 17:22 20768]
    S3 niscdk;niscdk;c:\windows\System32\drivers\niscdkl.sys [08/01/2008 00:38 11376]
    S3 nisdigk;nisdigk;c:\windows\System32\drivers\nisdigkl.sys [08/01/2008 00:21 11352]
    S3 nisftk;nisftk;c:\windows\System32\drivers\nisftkl.sys [20/12/2007 15:54 11344]
    S3 nispdk;nispdk;c:\windows\System32\drivers\nispdkl.sys [08/01/2008 00:38 11376]
    S3 nissrk;nissrk;c:\windows\System32\drivers\nissrkl.sys [22/02/2008 11:25 11336]
    S3 nistc2k;nistc2k;c:\windows\System32\drivers\nistc2kl.sys [08/01/2008 00:35 11312]
    S3 nistcrk;nistcrk;c:\windows\System32\drivers\nistcrkl.sys [14/02/2008 20:58 11360]
    S3 niswdk;niswdk;c:\windows\System32\drivers\niswdkl.sys [02/01/2008 13:14 11336]
    S3 nitiork;nitiork;c:\windows\System32\drivers\nitiorkl.sys [19/02/2008 23:56 11360]
    S3 niufurk;niufurk;c:\windows\System32\drivers\niufurkl.sys [22/02/2008 11:25 11368]
    S3 NiViFWK;NI-VISA FireWire Driver;c:\windows\System32\drivers\NiViFWKl.sys [19/07/2007 11:48 11384]
    S3 NiViPciK;NI-VISA PCI Driver;c:\windows\System32\drivers\NiViPciKl.sys [19/07/2007 11:56 11360]
    S3 niwfrk;niwfrk;c:\windows\System32\drivers\niwfrkl.sys [22/02/2008 11:25 11336]
    S3 nixsrk;nixsrk;c:\windows\System32\drivers\nixsrkl.sys [22/02/2008 11:25 11336]
    S3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [11/11/2009 10:44 7408]
    S3 usb6xxxkw;usb6xxxkw;c:\windows\System32\drivers\usb6xxxkw.sys [22/02/2008 11:05 11312]
    S4 AESTFilters;Andrea ST Filters Service;c:\windows\System32\AEstSrv.exe [04/01/2008 11:26 73728]
    S4 sptd;sptd;c:\windows\System32\drivers\sptd.sys [21/12/2007 13:27 639224]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
    bthsvcs REG_MULTI_SZ BthServ
    WindowsMobile REG_MULTI_SZ wcescomm rapimgr
    LocalServiceRestricted REG_MULTI_SZ WcesComm RapiMgr
    2009-11-22 c:\windows\Tasks\User_Feed_Synchronization-{4732595D-7B04-45EC-9764-97CC77276A1E}.job
    - c:\windows\system32\msfeedssync.exe [2008-07-30 07:33]
    uStart Page = hxxp://mail.live.com/default.aspx?wa=wsignin1.0
    IE: Add to Google Photos Screensa&ver - c:\windows\system32\GPhotos.scr/200
    IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\Office12\EXCEL.EXE/3000
    IE: Send image to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
    IE: Send page to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    Trusted Zone: northernbank.co.uk
    DPF: {D8575CE3-3432-4540-88A9-85A1325D3375} - hxxps://ebanking.northernbank.co.uk/html/activex/e-Safekey/NB/e-Safekey.cab
    FF - ProfilePath - c:\users\thecubanboys\AppData\Roaming\Mozilla\Firefox\Profiles\pp39cfdn.default\
    FF - prefs.js: browser.startup.homepage - www.myspace.com/thegoodfightni
    FF - plugin: c:\program files\Google\Picasa3\npPicasa3.dll
    FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava11.dll
    FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava12.dll
    FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava13.dll
    FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava14.dll
    FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava32.dll
    FF - plugin: c:\program files\Java\jre1.6.0\bin\npjpi160.dll
    FF - plugin: c:\program files\Java\jre1.6.0\bin\npoji610.dll
    FF - plugin: c:\program files\Microsoft\Office Live\npOLW.dll
    FF - plugin: c:\program files\Mozilla Firefox\plugins\np-mswmp.dll
    FF - plugin: c:\program files\Mozilla Firefox\plugins\NPLV80Win32.dll
    FF - plugin: c:\program files\Mozilla Firefox\plugins\NPLV82Win32.dll
    FF - plugin: c:\program files\Mozilla Firefox\plugins\nplv85win32.dll
    FF - plugin: c:\program files\Windows Live\Photo Gallery\NPWLPG.dll
    FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
    AddRemove-eBay Icon - c:\users\thecubanboys\AppData\Roaming\Desktopicon\uninst.exe
    Rootkit scan 2009-11-22 20:15
    Windows 6.0.6001 Service Pack 1 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
    @Denied: (A) (Users)
    @Denied: (A) (Everyone)
    @Allowed: (B 1 2 3 4 5) (S-1-5-20)
    "BlindDial "=dword:00000000
    [HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0001\AllUserSettings]
    [HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0002\AllUserSettings]
    - - - - - - - > 'lsass.exe'(788)
    c:\windows\system32\psqlpwd.dll
    c:\program files\Fingerprint Reader Suite\homefus2.dll
    c:\program files\Fingerprint Reader Suite\infra.dll
    - - - - - - - > 'Explorer.exe'(580)
    c:\windows\system32\btncopy.dll
    ------------------------ Other Running Processes ------------------------
    c:\windows\system32\nvvsvc.exe
    c:\windows\system32\rundll32.exe
    c:\program files\Fingerprint Reader Suite\upeksvr.exe
    c:\windows\system32\lkcitdl.exe
    c:\progra~1\AVG\AVG8\avgrsx.exe
    c:\windows\system32\lkads.exe
    c:\windows\system32\lktsrv.exe
    c:\program files\National Instruments\MAX\nimxs.exe
    c:\program files\National Instruments\Shared\Security\nidmsrv.exe
    c:\windows\system32\nisvcloc.exe
    c:\program files\National Instruments\Shared\Tagger\tagsrv.exe
    c:\program files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    c:\windows\system32\STacSV.exe
    c:\program files\Windows Media Player\wmpnetwk.exe
    Completion time: 2009-11-22 20:26 - machine was rebooted
    ComboFix-quarantined-files.txt 2009-11-22 20:26
    Pre-Run: 44,704,268,288 bytes free
    Post-Run: 44,365,357,056 bytes free
    - - End Of File - - D0E6777555741BECB9DA66E40F99D133
    HIJACKTHIS log
    Scan saved at 20:33:34, on 22/11/2009
    Platform: Windows Vista SP1 (WinNT 6.00.1905)
    MSIE: Internet Explorer v7.00 (7.00.6001.18319)
    C:\Windows\system32\Dwm.exe
    C:\Windows\system32\taskeng.exe
    C:\Windows\Explorer.EXE
    C:\Program Files\SigmaTel\C-Major Audio\WDM\sttray.exe
    C:\Program Files\Unlocker\UnlockerAssistant.exe
    C:\Windows\System32\rundll32.exe
    C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
    C:\Program Files\AVG\AVG8\avgtray.exe
    C:\Program Files\PowerISO\PWRISOVM.EXE
    C:\Program Files\IObit\IObit Security 360\is360tray.exe
    C:\Windows\ehome\ehtray.exe
    C:\Program Files\Windows Live\Messenger\msnmsgr.exe
    C:\Windows\ehome\ehmsas.exe
    C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    C:\Program Files\Logitech\SetPoint\SetPoint.exe
    C:\Program Files\Common Files\Logitech\khalshared\KHALMNPR.EXE
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\Windows\System32\mobsync.exe
    C:\Windows\system32\SearchFilterHost.exe
    C:\Windows\system32\wuauclt.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://mail.live.com/default.aspx?wa=wsignin1.0
    R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
    O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
    O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
    O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - c:\Program Files\Java\jre1.6.0\bin\ssv.dll
    O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    O2 - BHO: Browser Address Error Redirector - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll
    O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
    O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
    O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
    O4 - HKLM\..\Run: [SigmatelSysTrayApp] %ProgramFiles%\SigmaTel\C-Major Audio\WDM\sttray.exe
    O4 - HKLM\..\Run: [UnlockerAssistant] "C:\Program Files\Unlocker\UnlockerAssistant.exe "
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [NVHotkey] rundll32.exe C:\Windows\system32\nvHotkey.dll,Start
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe "
    O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
    O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
    O4 - HKLM\..\Run: [IObit Security 360] "C:\Program Files\IObit\IObit Security 360\IS360tray.exe" /autostart
    O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
    O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
    O4 - HKCU\..\Run: [Skype] "C:\Program Files\Skype\\Phone\Skype.exe" /nosplash /minimized
    O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    O4 - Global Startup: Logitech SetPoint.lnk = ?
    O4 - Global Startup: Nokia Nseries PC Suite.lnk = C:\Program Files\Nokia\NNPCS\RunLauncher.exe
    O8 - Extra context menu item: Add to Google Photos Screensa&ver - res://C:\Windows\system32\GPhotos.scr/200
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
    O8 - Extra context menu item: Send image to &Bluetooth Device... - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
    O8 - Extra context menu item: Send page to &Bluetooth Device... - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - c:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - c:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
    O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
    O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
    O9 - Extra button: @C:\Windows\WindowsMobile\INetRepl.dll,-222 - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\Windows\WindowsMobile\INetRepl.dll
    O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\Windows\WindowsMobile\INetRepl.dll
    O9 - Extra 'Tools' menuitem: @C:\Windows\WindowsMobile\INetRepl.dll,-223 - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\Windows\WindowsMobile\INetRepl.dll
    O9 - Extra button: (no name) - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
    O9 - Extra 'Tools' menuitem: Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
    O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
    O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O16 - DPF: {49312E18-AA92-4CC2-BB97-55DEA7BCADD6} (WMI Class) - http://support.dell.com/systemprofiler/SysProExe.CAB
    O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://gfx1.hotmail.com/mail/w2/resources/VistaMSNPUplden-gb.cab
    O16 - DPF: {5D6F45B3-9043-443D-A792-115447494D24} (UnoCtrl Class) - http://messenger.zone.msn.com/EN-GB/a-UNO1/GAME_UNO1.cab
    O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
    O16 - DPF: {D8575CE3-3432-4540-88A9-85A1325D3375} (e-Safekey) - https://ebanking.northernbank.co.uk/html/activex/e-Safekey/NB/e-Safekey.cab
    O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
    O20 - AppInit_DLLs: C:\Windows\System32\avgrsstx.dll
    O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
    O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
    O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: IS360service - IObit - C:\Program Files\IObit\IObit Security 360\IS360srv.exe
    O23 - Service: Lookout Citadel Server (LkCitadelServer) - National Instruments, Inc. - C:\Windows\system32\lkcitdl.exe
    O23 - Service: National Instruments PSP Server Locator (lkClassAds) - National Instruments Corporation - C:\Windows\system32\lkads.exe
    O23 - Service: National Instruments Time Synchronization (lkTimeSync) - National Instruments Corporation - C:\Windows\system32\lktsrv.exe
    O23 - Service: NI Configuration Manager (mxssvr) - National Instruments Corporation - C:\Program Files\National Instruments\MAX\nimxs.exe
    O23 - Service: NI Device Loader (nidevldu) - National Instruments Corporation - C:\Windows\system32\nipalsm.exe
    O23 - Service: National Instruments Domain Service (NIDomainService) - National Instruments Corporation - C:\Program Files\National Instruments\Shared\Security\nidmsrv.exe
    O23 - Service: NI PXI Resource Manager (nipxirmu) - National Instruments Corporation - C:\Windows\system32\nipalsm.exe
    O23 - Service: NI Service Locator (niSvcLoc) - National Instruments Corp. - C:\Windows\system32\nisvcloc.exe
    O23 - Service: National Instruments Variable Engine (NITaggerService) - National Instruments, Inc. - C:\Program Files\National Instruments\Shared\Tagger\tagsrv.exe
    O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\Windows\system32\nvvsvc.exe
    O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - Sonic Solutions - (no file)
    O23 - Service: ServiceLayer - Nokia. - C:\Program Files\Nokia\PC Connectivity Solution\ServiceLayer.exe
    O23 - Service: SigmaTel Audio Service (STacSV) - IDT, Inc. - C:\Windows\system32\STacSV.exe
    End of file - 10062 bytes
  5. 2009/11/22
    Uninstall Combofix:
    Go Start > Run [Vista users, go Start> "Start search"]
    Type in:
    Combofix /Uninstall
    Note the space between the "Combofix" and the "/Uninstall "
    Restart computer.
    Print these instructions out.
    NOTE. If any of the programs listed below refuse to run, try renaming executive file to something else; for instance, rename hijackthis.exe to scanner.exe
    ***VERY IMPORTANT! Make sure, you update Superantispyware, and Malwarebytes before running the scans.***
    STEP 1. Download SUPERAntiSpyware Free for Home Users:
    http://www.superantispyware.com/
    * Double-click SUPERAntiSpyware.exe and use the default settings for installation.
    * An icon will be created on your desktop. Double-click that icon to launch the program.
    * If asked to update the program definitions, click "Yes ". If not, update the definitions before scanning by selecting "Check for Updates ". (If you encounter any problems while downloading the updates, manually download and unzip them from here: http://www.superantispyware.com/definitions.html.)
    * Close SUPERAntiSpyware.
    PHYSICALLY DISCONNECT FROM THE INTERNET
    Restart computer in Safe Mode.
    To enter Safe Mode, restart computer, and keep tapping F8 key, until menu appears; select Safe Mode; you'll see "Safe Mode" in all four corners of your screen
    * Open SUPERAntiSpyware.
    * Click Scan your Computer... button.
    * Click Scanning Preferences/Control Center... button.
    * Under General and Startup tab, make sure, Start SUPERAntiSpyware when Windows starts option is UN-checked.
    * Click the Scanning Control tab.
    * Under Scanner Options make sure the following are checked (leave all others unchecked):
    - Close browsers before scanning.
    - Terminate memory threats before quarantining.
    * Click the Close button to leave the control center screen.
    * On the left, make sure you check C:\Fixed Drive.
    * On the right, choose Perform Complete Scan.
    * Click Next to start the scan. Please be patient while it scans your computer.
    * After the scan is complete, a Scan Summary box will appear with potentially harmful items that were detected. Click OK.
    * Make sure everything has a checkmark next to it and click Next.
    * A notification will appear that Quarantine and Removal is Complete. Click OK and then click the Finish button to return to the main menu.
    * If asked if you want to reboot, click Yes.
    * To retrieve the removal information after reboot, launch SUPERAntispyware again.
    - Click Preferences, then click the Statistics/Logs tab.
    - Under Scanner Logs, double-click SUPERAntiSpyware Scan Log.
    - If there are several logs, click the current dated log and press View log. A text file will open in your default text editor.
    - Please copy and paste the Scan Log results in your next reply.
    * Click Close to exit the program.
    Post SUPERAntiSpyware log.
    RECONNECT TO THE INTERNET
    RESTART COMPUTER!
    STEP 2. Download Malwarebytes' Anti-Malware: http://www.malwarebytes.org/mbam.php to your desktop.
    (Malwarebytes is free to use as a manual scanner. Payment is only required if you wish to have it run and update automatically which is not necessary for our purposes)
    Due to a bug in Malwarebytes, you may see in MBAM's log following entries:
    HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\atapi (Rootkit)
    HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\atapi (Rootkit)
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\atapi (Rootkit)
    DO NOT remove those entries!
    If you do, your computer will become UN-bootable.
    The issue has been fixed in the latest MBAM update, so, it's EXTREMELY important, you update MBAM before you run it.
    * Double-click mbam-setup.exe and follow the prompts to install the program.
    * At the end, be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
    * If an update is found, it will download and install the latest version.
    * Once the program has loaded, select Perform full scan, then click Scan.
    * When the scan is complete, click OK, then Show Results to view the results.
    * Be sure that everything is checked, and click Remove Selected.
    * When completed, a log will open in Notepad.
    * Post the log back here.
    The log can also be found here:
    C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt
    Or at C:\Program Files\Malwarebytes' Anti-Malware\Logs\log-date.txt
    RESTART COMPUTER!
    STEP 3.
    Post fresh HijackThis log.
    Do NOT attempt to "fix" anything!
  6. 2009/11/25
    thecubanboys
    Thanks,
    Sorry I've been working lots over the last few days so only getting a chance to do this now. The logs are below.
    SUPER ANTISPYWARE
    Generated 11/25/2009 at 01:26 PM
    Application Version : 4.31.1000
    Core Rules Database Version : 4310
    Trace Rules Database Version: 2175
    Scan type : Complete Scan
    Total Scan Time : 02:02:47
    Memory items scanned : 276
    Memory threats detected : 0
    Registry items scanned : 9265
    Registry threats detected : 0
    File items scanned : 173280
    File threats detected : 0
    MALWAREBYTES ANTI-MALWARE
    Malwarebytes' Anti-Malware 1.41
    Database version: 3229
    25/11/2009 15:31:34
    mbam-log-2009-11-25 (15-31-34).txt
    Scan type: Full Scan (C:\|D:\|)
    Objects scanned: 291334
    Time elapsed: 1 hour(s), 54 minute(s), 9 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 0
    Registry Keys Infected: 0
    Registry Values Infected: 0
    Folders Infected: 0
    Files Infected: 1
    (No malicious items detected)
    Folders Infected:
    Files Infected:
    C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\NEDHUKEQ\wcap[1].exe (Trojan.Dropper) -> Quarantined and deleted successfully.
    HIJACKTHIS
    Scan saved at 15:45:07, on 25/11/2009
    O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
    End of file - 9669 bytes
    Steven
  7. 2009/11/25
    Please download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    • Open JavaRa.exe again and select Search For Updates.
    • Select Update Using Sun Java's Website then click Search and click on the Open Webpage button. Download and install the latest Java Runtime Environment (JRE) version for your computer.
    Print this post out, since you won't have an access to it, at some point.
    1. Open HijackThis.
    2. Close all windows, except for HijackThis.
    3. Put checkmarks next to the following HijackThis entries:
    - O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
    - O4 - Global Startup: Logitech SetPoint.lnk = ?
    4. You should also checkmark following entries (these are unnecessary startups; no actual programs will be removed):
    - O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
    - O4 - HKLM\..\Run: [SigmatelSysTrayApp] %ProgramFiles%\SigmaTel\C-Major Audio\WDM\sttray.exe
    - O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
    - O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
    - O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
    - O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
    - O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    5. Click on Fix checked button.
    6. Restart computer.
    7. Post new HijackThis log.
  8. 2009/11/25
    thecubanboys
    Hi
    I've attached the HIJACKTHIS log below.
    Steven
    HIJACKTHIS
    Scan saved at 19:24:13, on 25/11/2009
    C:\Program Files\Java\jre6\bin\jusched.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    End of file - 8446 bytes
  9. 2009/11/25
    Your computer is clean :)
    1. Download Temp File Cleaner (TFC)
    2. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista:
    1. Click Start.
    8. Click OK
    3. Restart computer.
    4. Turn System Restore on.
    5. Make sure, Windows Updates are current.
    [SIZE= "4"]6. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately![/SIZE]
    7. Download, and install WOT (Web OF Trust): http://www.mywot.com/. It'll warn you (in most cases) about dangerous web sites.
    8. Run defrag at your convenience.
    9. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    10. Please, let me know, how is your computer doing.
  10. 2009/11/25
    thecubanboys
    Thanks very much for your help. The computer is running like new! I really really appreciate it.
    Can I delete all the programs i had to download?? Malwarebytes, Hijackthis, etc??
    Thanks again,
    Steven
  11. 2009/11/25
    You're very welcome :)
    I suggest, you run TFC weekly.
    Run Malwarebytes and Superantispyware monthly, or if you feel like your computer misbehaves.
    You can uninstall HJT.
  12. 2009/11/26
    thecubanboys
    Will do. Thanks again! You're a legend!
    Steven
  13. 2009/11/26
    You're welcome :)
