Resolved IE7 problems with URL address bar and Favorites
Discussion in 'Internet Explorer & Microsoft Edge' started by robls99, 2009/01/21.
  1. 2009/01/21
    robls99 Lifetime Subscription
    robls99 Well-Known Member Thread Starter
    I just had a new WinFast moutherboard put in and IE7 is acting strange. I had no problems with the old board. I'm using XP-Home.
    Desktop shortcuts take me to the chosen web site ok, but if I type any name in the address bar it just sits there and doesn't go anywhere.
    Also when I click on the star icon for Favorites it comes up with a large blank box but when I click on Favorites>Organize Favorites it properly shows my hundreds of organized favorites.
    I downloaded the current version of IE7 on top of mine but no change.
    What is going on?
  2. 2009/01/22
    Did you load the chipset drivers for the new mobo and then make a repair install of XP ? - both necessary with a new mobo.
    Have you tried a Reset of IE - Tools > Internet Options > Advanced ?
    Uninstall IE 7 through Add/Remove programs - this will roll you back to IE6 - test. Then install IE7 - test.
  5. 2009/01/22
  6. 2009/01/22
    Thanks for the update - glad to hear that Evan's solution worked for you :)
  7. 2009/01/22
    Excellent. Glad you got your problem resolved. :)
