IE7 Problem Revisited Please
Discussion in 'Internet Explorer & Microsoft Edge' started by ziggee, 2006/12/05.
  1. 2006/12/05
    ziggee
    ziggee Well-Known Member Thread Starter
    Lately I've started getting these Internet Explorer messages containing a yellow triangle with an exclamation point in them on quite a few of the pages I visit. I never had them before and I just want to know how to get rid of these warnings entirely, please.
    Thanks for any and all help!
    Barb
  2. 2006/12/05
    armestier
    armestier Inactive
    ziggee--If you can view the page and are not missing anything, I think you can forget about it. It is probably due to some IE Security Setting, such as not allowing third party cookies, or scripting.
    IE 7 seems to pick up more 'Errors on Page', etc than IE 6 probably due to the way it is written and it's enhanced security functions and not all websites are totally compatible with IE 7 yet.
    Ignore them :) If you want details double click on the yellow triangle. For the most part the web page displays correctly - if it does not is is probably not compatible with IE 7.
    There is a 'fix' for incompatibility, but I have not tried it ...
    http://www.enhanceie.com/ie/tweaks.asp
  5. 2006/12/05
    ziggee
    Thank you both for your help. PeteC, I tried the 'fix' and it is helpful. On some pages that message was coming up four times before I ever got to look at it!!! Armestier, I think it could be connected to third party cookies. Usually the ads loading on the page seem to generate the problem. Whatever is causing it, I'm glad to have this way around it for now, and hopefully we will soon be able to fix it permanently.
    Thank you both again.
    Barb
