IE6/OE6 security problems
Discussion in 'Internet Explorer & Microsoft Edge' started by ericblz, 2002/03/12.
  1. 2002/03/12
    ericblz Contributing Member
    ericblz Inactive Thread Starter
    Just upgraded to IE6/OE6 & the 2/11/02 security patch... having trouble with certain web sites- instead of a pop-up logon window, IE returns the error 'You are not authorized to view this page You do not have permission to view this directory or page using the credentials you supplied.'
    (e.g. www.webiard.com/iad )
    Changing the security level to low did not help. Upon adding this site to the trusted sites list, it functions properly and allows me to log in.
    Also having a possibly related problem accessing Hotmail via outlook express - it continually asks for the password and refuses to pull messages now. I modified the zone for outlook express from restricted to Internet, no change. Even added *.msn.com and *.hotmail.com to trusted sites, no luck again.
    Thanks!
    Eric
    San Diego CA
  2. 2002/03/12
    Welshjim
    Welshjim Inactive
    ericblz --Here is the message I get when I clicked on your link
    "The page must be viewed over a secure channel
    The page you are trying to view requires the use of "https" in the address.
    Please try the following:
    Try again by typing https:// at the beginning of the address you are attempting to reach.
    HTTP 403.4 - Forbidden: SSL required
    Internet Information Services
    Technical Information (for support personnel)
    Background:
    This error indicates that the page you are trying to access is secured with Secure Sockets Layer (SSL).
    More information:
    Microsoft Support "
    Yup, tried again https://www.webiard.com/iad
    Now get 403 error.
    HTTP 401.2 - Unauthorized: Logon failed due to server configuration
    Eric
  5. 2002/03/12
    I figured it out - the logon was set to anonymous. Case closed.
