IE5.5 SP1 Favorites menu button problem
Discussion in 'Internet Explorer & Microsoft Edge' started by ccwallin, 2002/02/01.
  1. 2002/02/01
    ccwallin
    ccwallin Inactive Thread Starter
    I had to recently downgrade from IE6 to IE5.5 SP1. My Favorites Menu button does not allow me to select any options. I can't even select "Organize" or other menu control items. I was able to turn on the "personalize" option but it does nothing.
  2. 2002/02/12
    Kevin Lifetime Subscription
    Kevin Well-Known Member
    Have you tried a "Repair "?
    ccwallin
    IE favorites
    I have not tried Repair. I guess I don't know what that means. Can you help me with that?
    Tom Wallin:)
  5. 2002/02/14
    garybeafl
    garybeafl Inactive
    Go to control panel and select the add/remove icon. Select IE5 and then click the add/remove button. It should give you an option of "repair ". You could also try going to Windows update and update to IE6 again.
