IE11 favourites - Properties window
Discussion in 'Internet Explorer & Microsoft Edge' started by Ludwig, 2017/01/12.
  1. 2017/01/12
    Ludwig
    Ludwig Well-Known Member Thread Starter
    I have URL links on my Favorites bar and was wanting to use the "Notes" Property on the "Details" tab to store some .. well um ... notes. this user [deliberately does not have admin rights on the machine.
    For some reason when I try to "Apply" it (or click OK), I get File Access Denied prompt "You'll need to provide administrator permission to apply properties to this file.". So I fill in the administrator password - it selects the name of my Admin Account for me.
    But then I get another File Access Denied prompt "You require permission from BRICK\<local std account userid> to make changes to this file". The user quoted is the user I am logged into. Using Try Again just reopens this same prompt. Only option is to "Cancel".
    Is there a way to get IE11 on Windows 10 to allow me to us this Property field?
  2. 2017/01/12
    Ludwig
    I have also just tested this on the Admin Account .. I get the same series of two prompts - "need administrator permission" ... which the logged in userid has, followed by File Access Denied prompt "You require permission from <logged in userID> to make changes to this file").
    Given I have admin rights already why would this be denied?!?
  5. 2017/01/13
    Ludwig
    Thanks for the idea, I've experimented with doing this. The result is ... user is already the owner of the file so when I "change" it doesn't actually change (because the user is already the owner).
    Question: Is there any reason Microsoft wouldn't want to allow a user to update the properties of their own files by default anyway? After all it's the current user that is allowed to, & does actually, create the favorites entry in the first place? And it doesn't even allow an administrator to do it!
  6. 2017/01/13
    Open a command prompt as admin.
    Use this command to set Read-Write-Modify permissions (of Favorites for your standard account):
    icacls "C:\Users\YOUR USER NAME\Favorites" /grant YOUR USER NAME:(OI)(CI)F /T
    icacls - command to modify access control list of files
    F = Full control
    CI = Inheret Containers (sub folders)
    OI = Object Inheret (files in folder)
    /T = Apply recursively (apply to all existing subfolders and all files)
    You should then be able to modify all aspects of Favorites.
    This problem often comes up as a result of upgrading operating systems. During an upgrade, file permissions sometimes change.
  7. 2017/01/13
    Ludwig
    Thanks for icacls command. With CD C:\Users\myUID selected, "icacls .\favorites /grant myuid: (OI)(CI)F /t" successfully processed all files (& folders), with 0 failures.
    [NB no space between : and open bracket ... saves showing a smilie in this post]
    However .. result is the same. I still get the "give me the admin user password" followed by "you need permission from myUID". So still can't save anything in the properties field (Notes or Description).
    A check of security settings shows it has all the permissions available are ticked - see uploaded file Capture.JPG.
  8. 2017/01/13
    Try rebooting.
  9. 2017/01/14
    Ludwig
    A reboot makes no difference.
  10. 2017/01/14
    Sounds like a registry value is not getting properly toggled. Try changing your account type to an Administrator, temporarily. See if you make the necessary edits, then revert back.
  11. 2017/01/15
    Ludwig
    Changed my account type, rebooted (reason: "make extra sure ..."), and logged back in. Same loop with same net effect .. it won't let me use the property fields :(
    Maybe I'm destined to "just live with it" :eek: The PC is brand new PC with a clean Win10 build too (bought from a shop), so I'd expect it to be a clean install rather than an upgrade from Win8.x.
  12. 2017/01/15
    I agree with you as you would expect a clean install of 10. Seen worse happen before. Take it back to the shop and ask them about your problem and ask if it was a clean install or an upgrade from Win 7 or 8.
  13. 2017/01/16
    Looks to me that function is just FUBAR. I tried it with 3 Win10 installations and can't get it to work. I tried an old IE7 install, same thing. It just doesn't seem to work.
    Only post I could find is one from 2011: Adding notes/descriptions to IE favorites which has no working solution either.
    Ludwig likes this.
  14. 2017/01/19
    Ludwig
    I think I need to declare this is an unsolvable problem - needs Microsoft to "enable it" (why are they blocking it from working, seems more effort required than not blocking it in the first place!?!).
    How can I mark this thread as "answered, but sadly un-Solvable" ??
  15. 2017/01/20
    You don't mark it. Just leave it 'as-is' ;)
