IE does not connect to Internet?
Discussion in 'Internet Explorer & Microsoft Edge' started by ron2490, 2006/05/19.
  1. 2006/05/19
    ron2490
    ron2490 Inactive Thread Starter
    I can connect to internet using firefox no problem,but when i try to connect with ie 7 beta or ie 6 it just searches forever and even after 15 minutes still does not connect.What could I have done to cause this and also what can i do to fix it.
    Ron:confused:
  2. 2006/05/19
    Whiskeyman Inactive Alumni
    What firewall are you using if any and is it set to allow IE6 or 7 access to the Internet?
    ron2490 - Welcome to the Board :)
    If it is not a firewall problem as Wiskeyman suggests try running WinsockFix, available here
  5. 2006/05/19
    ron2490
    Wiskeyman
    Looked at mcCafee Ie7 has full access
    Thanks Ron
    PETE C
    __________________
    Tried winsockfix . No Luck,problem still the same
    Ron
  6. 2006/05/19
    Ron
    Do have either of the browsers as default? On my system in IE - IE should check if it is the default browser is unchecked and in Firefox - Firefox should .... is unchecked.
    This is clearly an IE problem - I suggest you run System File Checker.
