IE 7 Knowledge Base Articles & Resources
Discussion in 'Internet Explorer & Microsoft Edge' started by Bill Castner, 2006/11/02.
  1. 2006/11/02
    Bill Castner
    Bill Castner Inactive Thread Starter
    Update for Exchange 2003 (KB911829) - This update restores functionality to Microsoft Exchange Outlook Web Access due to changes being made to Internet Explorer in the upcoming Microsoft Windows Vista Beta release:
    http://www.microsoft.com/downloads/...8a-08eb-4976-bc68-a03ebe3a2552&displaylang=en
    Error message when you try to install Internet Explorer 7: "Internet Explorer could not be installed "
    http://support.microsoft.com/kb/917925/en-us
    How to perform a repair installation of WinXP if IE7 is installed
    http://support.microsoft.com/kb/917964/en-us
    When you use Internet Explorer 7 to visit a Web site, you may receive error messages that state that you do not have the most current version of Internet Explorer
    http://support.microsoft.com/kb/923196/en-us
    How to use Reset Internet Explorer Settings (RIES):
    http://support.microsoft.com/kb/923737
    The Compose Message form stops responding after you install IE7 and the S/MIME control on an Outlook Web Access client in Exchange Server 2003
    http://support.microsoft.com/?kbid=924334
    You receive a security warning in Internet Explorer 7 when you visit a Web page that is hosted on a secure Web site
    http://support.microsoft.com/kb/925014/en-us
    The Read Mail toolbar button is not visible in Internet Explorer
    http://support.microsoft.com/kb/926068/en-us
    Error message when you start Internet Explorer 7 or try to access a Web site: "Internet Explorer cannot display the Webpage "
    http://support.microsoft.com/kb/926431/en-us
    RSS feeds may not be updated in Internet Explorer 7
    http://support.microsoft.com/kb/926447/en-us
    In Internet Explorer 7, RSS feeds are not listed, or you cannot subscribe to RSS feeds
    http://support.microsoft.com/kb/926448/en-us
    Internet Explorer 7 does not start correctly or stops responding unexpectedly
    http://support.microsoft.com/kb/926449/en-us
    Icons that are associated with the current version of Internet Explorer are incorrect after you install or uninstall Internet Explorer 7
    http://support.microsoft.com/kb/926715/en-us
    The installation of Windows Internet Explorer 7 never finishes
    http://support.microsoft.com/kb/926716/en-us
    Availability of Windows Internet Explorer 7
    http://support.microsoft.com/kb/926874/en-us
    Additional articles
    Diagnosing and resolving problems with Tabbed Browsing in IE7:
    http://msmvps.com/blogs/spywaresucks/archive/2006/10/24/203178.aspx
    Internet Explorer 7 is stuck at the first run welcome page
    http://msmvps.com/blogs/spywaresucks/archive/2006/10/19/188482.aspx
    IE7 - will it be installed automatically on SBS2003 R2 systems running WSUS in its default configuration?
    http://msmvps.com/blogs/spywaresucks/archive/2006/10/12/171459.aspx
    Make HP Director software play nice with IE7:
    http://msmvps.com/blogs/spywaresucks/archive/2006/10/22/197647.aspx
    Fix: Problems with IE and NitroPDF:
    http://msmvps.com/blogs/spywaresucks/archive/2006/10/21/193880.aspx
    Keyboard shortcuts for IE7:
    http://msmvps.com/blogs/spywaresucks/archive/2006/10/21/193626.aspx
    Windows Search Guide in IE7
    http://blogs.msdn.com/ie/archive/2006/10/23/windows-search-guide-in-ie7.aspx
    Slow Start Up
    http://www.enhanceie.com/ie/troubleshoot.asp
    Resources
    Information Index for IE7
    http://msdn.microsoft.com/ie/infoindex/default.aspx
    Internet Explorer 7 Quick Reference Guide
    http://blogs.msdn.com/ie/attachment/715071.ashx
    EnhanceIE.com - Add-ons, Tweaks, Troubleshooting & more
    IE7 Solutions Center
    http://support.microsoft.com/ph/8722
    Source and to keep current on IE 7 changes:
    MS-MVP Sandi Hardemeir
    http://www.ie-vista.com/index.html
  2. 2006/11/04
    Bill Castner
    FIX: IE 7 Installation Failure: Access Denied
    This is a variation on a much written about "fix. "
    The original fix was suggested back in the XP Service Pack 2 installation days, (and can be found on the AUMHA site here:
    http://aumha.net/viewtopic.php?t=8125) and has been resurrected as an approach to IE 7 installation errors involving Access Denied in the installation logs.
    Unfortunately, that "fix" can take hours -- even days -- depending on the size of your hard drive and the number of folders.
    It also does nothing about Ownership or ACEs on the registry. The following takes just a minute to run, and then you will be able to successfully install IE.
    Here is my modified 'fix' that has been tested:
    First, download, unzip and move to \Windows\System32 the files:
    REGINI.EXE :
    http://www.dynawell.com/reskit/microsoft/win2000/regini.zip
    SUBINACL.EXE :
    http://www.microsoft.com/downloads/details.aspx?FamilyID=e8ba3e56-d8fe-4a91-93cf-ed6985e3927b
    Second, open notepad, and copy/paste the following:
    subinacl /subkeyreg HKEY_LOCAL_MACHINE /setowner=administrators
    subinacl /subkeyreg HKEY_CURRENT_USER /setowner=administrators
    subinacl /subkeyreg HKEY_CLASSES_ROOT /setowner=administrators
    subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f
    subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f
    subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f
    subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=system=f
    subinacl /subkeyreg HKEY_CURRENT_USER /grant=system=f
    subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=system=f
    regini C:\reg_fix.txt
    cls
    REG ADD "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached" /v "{A4DF5659-0801-4A60-9607-1C48695EFDA9} {00214E6-0000-0000-C000-000000000046} 0x401" /t REG_DWORD /d 1
    Do a File, Save as, C:\fix_reg.cmd
    Third, open notepad again and paste the following:
    \Registry\Machine\Software [1 5 10]
    \Registry\Machine\Software\Microsoft\Internet Explorer [1 5 10]
    \Registry\Machine\Software\Microsoft\Internet Explorer\SearchUrl [1 5 10]
    Do a File, Save, c:\reg_fix.txt
    Fourth, as Adminitrator use Control Panel, User Accounts, to create a brand new Administrator priviliged user.
    • Logout and logon as this new user;
    • Now reboot XP, and start hitting the F8 function key early and often;
    • In the Advanced Boot Menu that appears, choose Safe Mode with Networking, and logon as the newly created Administrator-type user
    Fifth, do a Start, Run, cmd
    Type:
    C:
    CD \
    fix_reg.cmd
    Reboot when finished. Again hit the F8 functioin key early and often and again logon in Safe Mode with Networking as the New user created earlier.
    Finally Install IE 7.
    Regards to all.
    Bill Castner
