IE 5.5 not saving options
Discussion in 'Internet Explorer & Microsoft Edge' started by deanwv, 2002/09/20.
  1. 2002/09/20
    deanwv
    deanwv Inactive Thread Starter
    i use IE 5.5sp2..... i do NOT want to search from the address bar... when a site is not there, i just want the internal unable to connect message to come up, instead of going into msn search. i went to tools, internet options, advanced, and checked "do not search from address bar" (or whatever it really sez), and saved. but, the next time i entered a site that wasn't there, the stupid search page came up again. i checked, and the do not search box had gotten unchecked. i re-checked the box (circle, actually hehe) and saved again. same result the next ti,e.
    so, i went to the options thru control paned, made the change, saved. guess what? it didn't stay checked again!
    any ideas what's going on? i tried the internet explorer repair tool twice now.
  2. 2002/09/22
    Daizy
    Daizy Inactive
    You're hitting "apply ".....then "ok" ?
    Daizy
