ICS not showing but works
Discussion in 'Networking (Hardware & Software)' started by spanner2003, 2003/04/01.
  1. 2003/04/01
    spanner2003
    spanner2003 Inactive Thread Starter
    I'm running xp on 4 pc's all networked together, On one pc after a network crash I lost ICS icon and can not see it in network conn's it was there before and it's there on the other two pc's. I've done a reload over the top, A full Reload is not an option......
  2. 2003/04/01
    Ski52
    Ski52 Inactive
    I have 4 machines networked at home, 2-XP Pro, 1-2K & 1-98?, I have no icons for connection anywhere - they all have Internet thru the main machine which has the cable modem (using ICS). The less Icons I see, especially when it works, the better. Why do you have to have an Icon??
    Ski
    spanner2003
    if you go to Network Connections and then to properties you can had an icon in tast bar when connected. on my pc i should had a high speed connection to adsl but it's not there but it works.....
  5. 2003/04/02
    spanner2003
    Xp pro Network problem
    This is an update on previous posting..... edit note - I merged the two threads together here - less confusing - Newt
    I run 4 pc's all on xp pro
    all running through 1 pc and out on to broadband
    all pc's run ok all connect to the net ok..... I have display in task bar on connection on all pc's .... on main pc I get the broadband icon and network icon... on the others, network icon and all but 1 high speed internet connected to broadband icon......
    on the one there is no icon in the task bar and if I go to the network connection page the high speed connection link is missing to but the internet email all work ok
