icon action drop down box [right click menu]
Discussion in 'Windows XP' started by bg9208, 2009/03/05.
  1. 2009/03/05
    bg9208
    bg9208 Inactive Thread Starter
    Hello,
    What I refer to is the drop down box which appears when one right clicks a desktop icon. A number of unwanted actions appear in mine. Is it possible to remove these unwanted items and, maybe, add other useful actions?
    TIA
  2. 2009/03/05
    ShellExView is the easiest way of dealing with this, rather than dabbling directly in the Registry.
    bg9208
    Thanks Pete - problem sorted in less than 15 minutes. Gotta to be close to a record!!
  5. 2009/03/05
    You're welcome :)
