I need help removing J2SE Runtime Environment 5.0 Updates
Discussion in 'Windows XP' started by TinyTuba822, 2007/10/29.
  1. 2007/10/29
    TinyTuba822
    TinyTuba822 Inactive Thread Starter
    Normally, I'd use the add/remove programs to do it, but I can't. When I go to click on J2SE Runtime Environment 5.0 Updates, there is no remove button to click on. Is there another way I can remove it?
  2. 2007/10/29
    Christer
    Christer Geek Member Staff
    From KB290301:
    Running that utility will not uninstall anything (right?), only remove the entries in Add/Remove Programs.
    I have no solution up my sleeve but we can start trouble shooting by going to Start > Control Panel > Java > "java tab" > check which versions of Java are listed and which versions are "active ". Compare that "list" to which versions appear in Add/Remove Programs. Post back with the results.
    Christer
  5. 2007/10/30
    Christer
    There was a similar thread a few weeks ago: Java Runtime Environment in which the resolution was to uninstall all versions, in the reverse order, from Add/Remove Programs and when all cleared, install the latest version. The problem here seems to be "orphaned" entries in Add/Remove Programs and I want TinyTuba822 to confirm that they all are "orphaned" or which one(s) are.
    When you install a new version of Java, it is in most cases intended to correct a security issue. Most (?) people just install the new version on top of the previous version(s) and they stack up in Add/Remove Programs. I wonder if the security issue is corrected if the previous version(s) is/are left installed? I recommend my own procedure to always uninstall the previous version (through Add/Remove Programs) prior to installing the new version.
    Christer
  7. 2007/10/30
    Definitely not - I have had notice from Secunia Software Inspector of vulnerabilities in earlier versions of Java - which were still installed on running their scan even though the latest version was installed. This was resolved by uninstalling the earlier versions.
    I recommend that everyone should sign up to Secunia Software Inspector for email notifications of when their vulnerability database has been revised so that a fresh scan can be made and updates applied if necessary.
  8. 2007/10/31
    TinyTuba822
    I used windows installer to get it off, thanks! Orphaned as in inactive? I don't use them, so yes they are.
