I keep hearing my own voice!!
Discussion in 'Windows XP' started by nobbie_ferguson, 2005/08/19.
  1. 2005/08/19
    nobbie_ferguson
    nobbie_ferguson Inactive Thread Starter
    Does anyone know how i can stop my speakers from broadcasting what goes into my microphone? It happens all the time, when im on windows, in games amd using chat software. I'm sure its really easy to fix i just cant find the right button.
  2. 2005/08/21
    vbmark
    vbmark Inactive
    Try this:
    Under control Panel open "Sounds and Audio Devices ".
    On the "Volume" tab in the "Device Volume" box click "Advanced ".
    On the "Play Control" screen, under the menu item "Options" click "Properties ".
    Make sure that "Playback" is the selected radio button and click OK.
    Back on the "Play Control" screen look for the column for "Microphone ".
    Make sure that the "Mute" option has a check mark in it.
    I think this will work.
