I have problem enable Guest user
Discussion in 'Windows XP' started by emia, 2009/06/21.
  1. 2009/06/21
    emia
    emia Inactive Thread Starter
    I'm use Windows XP (SP2) version
    I create user account :
    ( "Power Access User" ?administrator
    ( "Limited User" ?limitduser
    ( "Guest User" ?guest
    Part.A
    (1) But that "Limited User V. Guest " how diff?
    Part.B
    (2) Enanle "Guest" User is safe to use ?
    (3) some coffee shop that computer I see:
    No Windows [Start]
    can't mouse right click
    can't access C:\,
    can't any files in C:\*.*, else "documents and setting\guest "
    can't Ctrl+Alt+Delete
    can't Alt+Tab
    can't F1,help
    can't cmd
    can't modify/changed regedit value
    this is "guest" user function ?
    would you mind to help me?
    many thanks!
    emia,
  2. 2009/06/21
    emia
    but that "Guest" user that login "Guest" name, can changed other login name ?
    emia,
    To rename the Guest Account .....
    Control Panel > Administrative Tools > Local Security Policy.
    Then, in the tree at the left, open
    Security Settings > Local Policies > Security Options.
    In the right pane you will see ....
    Accounts: Rename guest account [current name]
    Double click on that entry and rename the guest account as you wish
  6. 2009/06/22
    mastermind2009
    mastermind2009 Inactive
    The symptoms that u have said seems that the user account u r using has gone corrupt..
    Are u using a desktop or a laptop?
    Try the following steps:
    1. whenever turning on your computer, start tapping f8.
    2. From advanced boot options, go to safe mode with networking.
    Check there ..
    If nothing works.. Do a recovery.
    Have a nice time.
    bye..
  7. 2009/06/22
    mastermind2009
    I think you are confusing the OP - his original post - as I read it - is a series of questions, not a problem as such.
