i have a problem with the cd-rom
Discussion in 'Windows XP' started by Sparda, 2010/02/27.
  1. 2010/02/27
    Sparda
    Sparda Inactive Thread Starter
    "Cannot delete...files on this CD-ROM drive are read only. You cannot copy or move..." so i go to a file, right click and go to the properties. I deselect read-only and apply. then i get a message saying that "an error occurred applying attributes to the file... Access is denied." I dont know what is it.. please help
  2. 2010/02/27
    Whiskeyman Inactive Alumni
    You cannot delete files on a CD-R disk or using a CD-Rom drive.
    Sparda
    i dont know what why is cd-rom i look at the computer and is Dvd Rom i dont understand???
  5. 2010/02/27
    wildfire
    wildfire Getting Old
    CD / DVD = ROM - Read Only Memory
    CDR /DVD R = WORM - Write Once Read Many
    Even RW discs need formatting or packet recording so it's not simply a case of changing what's already there.
    Buy an external HD or memory stick if you want the flexibility of a Hard Drive.
  6. 2010/02/27
    Sparda
    i try with a dvd and is the same what is the solution for this error, the other computer that i have was not a problem ???
  7. 2010/02/27
    Sparda
    Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive. When i put a Dvd is the same message.
  8. 2010/02/27
    surferdude2
    surferdude2 Inactive
    Sparda, It would help speed things along if you would complete the list of your System Details.
    To do that, click on User CP at the top of this thread, left side. Then click Edit System Specs. Enter all the information that applies to your system and tag all boxes that apply. When finished, click the Save Changes button at the bottom of the page.
    Then click the "Edit Options" link. Scroll down to the System Specifications" field and change the scrollable setting to read Yes. Finally, click the Save Changes button at the bottom and you'll be all done.
    If you need help getting some of the necessary information, you can use a free program like Everest and it will supply all you need.
  9. 2010/02/27
    markp62
    markp62 Geek Member Alumni
    Are you perhaps using software such as InCD, which can read and write to a CD-RW disk like a hard drive?
    A CD-ROM or a DVD-ROM cannot be written to, deleted from, file attributes changed or any other kind of altering.
    A CD-R or DVD-R can be written to only once, once there it is permanent.
    A CD-RW or DVD-RW can be formatted such as for InCD, completely erased, files changed, attributes changed, files added or deleted, much like a hard drive.
    BTW, could you use complete sentences with punctuation on here. We would rather not reconstruct sentences on top of figuring out what advice to give you.
