I got a big problem
Discussion in 'Windows XP' started by Troniferus, 2003/05/05.
  1. 2003/05/05
    Troniferus
    Troniferus Inactive Thread Starter
    Ok here's the deal and hopefully someone knows a way around it.
    I have a 950mHZ with a 60GB and 20GB HDs. On the 60 I have XP installed and on the 20 had 98 installed.
    The 20 was the original HD from the factory, but I installed the 60 once I got the comp and slaved the 20.
    Anyhow, I set a password the otherday (last wednesday) and inadvertently forgot it by Friday (I have no idea how, I normally write it down somewhere).
    The only hint I left myself was my cell phone model "kyocera. "
    What I've since done is installed XP over 98 on the 20 gig and made it the master and the 60 the slave.
    What I was wondering if anyone could answer is if there is a backdoor I could find on the 60 gig (the HD that is password locked out currently if I have it set as master) that I could find since I have access to the files and everything via the 20 gig that would let me find out what the password is or disable it.
    Anyone have any ideas?
    I want to thank you right now just for reading this far and in advance for any help you might be able to give me.
    Hopefully the password will come to mind, but I've tried most of my original pws.
    Thanks again.
  2. 2003/05/05
    As clearly stated in Rule #6 that you agreed to when you registered, we don't help with password crack attempts.
