Resolved I.E. 9 and Flash Player
Discussion in 'Internet Explorer & Microsoft Edge' started by Alicia J, 2011/04/09.
  1. 2011/04/09
    Alicia J Lifetime Subscription
    Alicia J Geek Member Thread Starter
    I have a netbook with Windows 7 Home Premium SP1 32 bit and was wondering if I install I.E. 9, if I will have any problems with flash player. I have read some issues and am not sure if they apply to 32 bit systems.
    I have a PC with Windows 7 Home Premium SP1 64 bit. If I install I.E. 9 will I have the option to run I.E. 9 in a 32 bit or 64 bit? I'm running I.E. 8 with the default I.E. for 32 bit. I understand flash player won't run on I.E. 9 64 bit.
  2. 2011/04/09
    I have a laptop with 7 Home Prem and IE9 and have no problems with Flash
    Do you have. 32 or 64 bit? Do you have SP1 installed?
  5. 2011/04/09
    Have both. Laptop 64 and Desktop 32 bit. SP1 on both.
  6. 2011/04/09
    So does I.E 9 installed on a 64 bit through windows update install both the 32 and the 64 bit version of I.E. ?
  7. 2011/04/09
    I don't know. Would think that just for the bit that is installed.
  8. 2011/04/09
    Don't install it via Windows Update.
    Just go to Internet Explorer Home and download IE9 (save it to hard drive). Close all browser windows and double click the download.
  9. 2011/04/10
    Okay. Will it install the 32 and 64 version on my 64 bit system?
  10. 2011/04/10
    You are going to be old before your time worrying about it. Install it and be done with it. :D
  11. 2011/04/10
    Too late for that, the old part that is. :)
  12. 2011/04/10
    Yes it will
  13. 2011/04/10
    This beta does run on x64.
  14. 2011/04/10
    Thanks for all the information guys. I'll give it a try and post again if I have any issues.
