I click on desktop icons and it goes to recycle bin
Discussion in 'Windows XP' started by Sharptooth, 2004/06/11.
  1. 2004/06/11
    Sharptooth
    Sharptooth Inactive Thread Starter
    When I click on a desktop icon it deletes it puts it in the recycle bin....I click on icons on my taskbar and they work just fine....just the ones on my desktop.
  2. 2004/06/11
    Do you have SP1 installed?
    And it couldn't hurt to try this from Kelly's Korner #64 right hand column.
    Sharptooth
    Thanks, works
    Thanks Newt, I download the file from Kelly's Korner and it fix it. Sorry it took a while to get back to you, I did want to let you know. Thanks a lot.
  5. 2004/06/12
    Appreciate the response. That site has a ton of good stuff. Just a bit of a pain finding what you want sometimes.
