Hub or Switch?
Discussion in 'Networking (Hardware & Software)' started by mojo13, 2004/02/17.
  1. 2004/02/17
    mojo13 Lifetime Subscription
    mojo13 Well-Known Member Thread Starter
    I have four computers getting DSL through a router. One of the computers is in the backroom and I would like to use that cable to connect more laptops to the DSL. What do I need to do this? A switch or a hub? :confused:
  2. 2004/02/17
    Either one will do.
    Based on the fact that the per-port cost of a switch is about the same as that of a hub and that switches are much better performers than hubs, I'd opt for a switch.
    - Hub max speed is 10Mbps. Switch is 100Mbps.
    - Hub (at least any I could afford) is half-duplex (send or receive) while switch is full-duplex (send and receive at the same time).
    - Hub shares it's available bandwidth (all 10Mbps of it) amongst the connected devices. Switch will provide the full 100Mbps to each connected device.
    - Hub has no idea who is connected or where so any conversations on your local network are started with a broadcast by the PC that is heard by all your devices. Switch will direct the packet to the other device rather than having to depend on broadcast/response to establish the connection.
    Thanks Newt, that is what I needed to know.
