HP6553 Not booting all way
Discussion in 'PC Hardware' started by ltrobb, 2002/12/23.
  1. 2002/12/23
    ltrobb
    ltrobb Inactive Thread Starter
    Working on an HP 6553 and I can not get it to boot all the way up. It gets to blue screen "Expanding possibilities HP screen then goes blank, not black but blank. Nothing affects it. I was able to get into f8 once but then on reboot- it just went back to this blue screen then blank again. CD rom lights, floppy does not, cpu fan runs, hard drive operates(Had in another unit). I know this CPU was disturbed before I got it and am not sure what's going on. Could this be a bad ribbon? Any help is much appreciated.
  2. 2002/12/24
    Lonny Jones
    Lonny Jones Inactive Alumni
    Hi ltrobb
    If you havent already it might help to post your ? in other forums
    See if this link work's it to the hp it resource center forums
    Let me know if it doesnt.
    http://bizforums.itrc.hp.com/cm/CategoryHome/0,,405,00.html
    Try pressing (and holding)ctrl when black screen with flashing c prompt is visable to get into startup menu and try safe mode
    Hp pc are a little differnt then win instructions for startup menu.
    also to get into an hp bios usualy just press an hold anykey youl get a stuck key message then you can enter bios
    Might help to in bios reset to default save changes & exit.
    Lon
