HP Photosmart 1215 print problem
Discussion in 'PC Hardware' started by SCFrance, 2013/07/08.
  1. 2013/07/08
    SCFrance
    SCFrance Well-Known Member Thread Starter
    My 1215 won't print cyan or yellow. I've replaced the color cartridge and have run all 3 cleaning options, bur those 2 colors won't work... not even a little. I really like this old printer and I don't want to give up on it until I'm sure it's not repairable.
  2. 2013/07/08
    Try uninstalling it and then reinstall it. Or check for driver updates which I don't think would matter.
    Hi SCFrance. I agree with Bill. I would update the driver for the printer if you haven't done that yet. Also try re-seating all of the cartridges since its possible that they are not fully inserted in the printer.
