hp laser jet 1200
Discussion in 'PC Hardware' started by z4u, 2005/08/07.
  1. 2005/08/07
    z4u
    z4u Inactive Thread Starter
    recently i m facing problem in my laser jet 1200 printer the problem is during printing process printer making a sound like very noise like running a motor and stop printing the sound is very noise and paper stop printing inlast i turn off printer and turn on printer again and re print can u help me what's the problem in printer what is the solution
    thanx
    z4u,
  2. 2005/08/07
    Hi,
    It may be a matter of cleaning the drive rollers:
    http://h20000.www2.hp.com/bizsuppor...esId=29789&prodTypeId=18972&objectID=bpl10512
    Cleaning and maintenance:
    http://h20000.www2.hp.com/bizsuppor...sId=29789&prodTypeId=18972&supportTaskId=2768
    Check for any buildup of dust inside. It may be worth getting a can of compressed air, taking the printer outside and blowing the dust out.
    Check for any buildup of toner.
    Check through the User Guide/Manual. Sometimes they point out what to look for and where to look.
    Have a look through the software/driver downloads. I see there is a "patch" for Win XP.
    http://h20000.www2.hp.com/bizsuppor...askId=135&prodSeriesId=29789&prodTypeId=18972
    Print some self-test pages. If there are no noises it may be due to bad drivers or a communication problem to the computer (but I would think it was more likely to be drive rollers needing cleaning).
    z4u
    k
    thanx mattman
    tonight i will try to clean the ruller by using instruction of hp webpages
    i hope it will fix otherwise i will change the ruller. can i do myself to clean or
    change ruller and when it needed to change the ruller..
    thanx again
    z4u,
    Yes z4u, it seems quite easy to clean or change the pickup roller. It would be something that you should check and clean occasionally.
    I would clean it well first and see if the noise was reduced. If the noise was still there it may need a second cleaning or replacement.
    Have a look on the drivers CD and also in the HP utilities program (Toolbox). There may be some information there as well about what parts to keep clean or inspect for wear.
