How to uninstall Authorware web player
Discussion in 'Other PC Software' started by crezza, 2008/05/14.
  1. 2008/05/14
    crezza
    crezza Inactive Thread Starter
    Windows keeps shutting down on my laptop, I've done a factory reset and reinstalled windows but still keeps happening, it started after installing an Authorware web player for my learn direct course. I've done a Hack this log on another thread thinking i may have a virus but have been told there wasn't any malware in my log so must be down to the Authorware web player not being compatible with Vista, I've looked in add remove programes but it isn't there. Hope someone can help. Thanks
  2. 2008/05/14
    After you did the factory reset did you reinstall this program?
    Have you looked on their web site for unistall information?
    crezza
    I probably did reinstall it, because when i try to access my course i think it automatically installs it. i'll have a look on the website and if its no good i'll restore the factory settings again, thanks:)
  5. 2008/05/15
    crezza
    I done a factory reset again just incase the Authorware player was still on there but still having the same problem, was ok for about an hour but then shut off. Might give Acer a call and see if i can send it back as i've only had it 8 months so its still under warranty:(
  6. 2008/05/15
    The pc could be overheating. If you open the case do you see a ton of dust?
  7. 2008/05/15
    crezza
    Its a laptop, could this be opened?
    mind you saying that about overheating u may be right, i always have it on a cushion on my lap and it does feel hot at the bottom. I'll see how it goes,
    thanks
  8. 2008/05/15
    crezza
    So far so good, left it on the table and its been on now for about 2 hours and hasn't gone off yet, won't be putting it on a cushion any more...lol
