Resolved How to stop System Integration Pop-up in Thunderbird?
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Barry, 2016/12/28.
  1. 2016/12/28
    Barry
    Barry Well-Known Member Thread Starter
    233
    Southern California
    Computer Experience:
    intermediate
    I am using Thunderbird 45.5.1 and Windows 10 home X64 Version 1607. Every time Thunderbird opens, a pop-up appears for System Integration. How can I get this pop-up to stop appearing?
  2. 2016/12/28
    1,093
    Fairfax, VA
    echo $experienced;
    Set TB as the default email program in both of these locations:
    Tools > Options > Advanced tab > System Integration > checkmark "Always check to see..."
    Control Panel > Default Programs > set Thunderbird as defaul email program.
    eisneun
    eisneun Well-Known Member
    208
    socal
    Intermediate
  5. 2016/12/28
    1,093
    Fairfax, VA
    echo $experienced;
    That bug is from 2014 and has been fixed, though the issue may be specific to the user's system he can try adding that line to the thunderbird preferences javascript file.
  6. 2016/12/28
    Barry
    233
    Southern California
    intermediate
    Yes, I did see the 2014 bugzilla suggestion, but I didn't feel it related to current software. Also, I don't know how to input this line to Java script.
    Tony, I've tried all variations of what you suggested, but nothing has any impact. Are there any other possibilities? This is my 95-year-old mother's computer, and everything must be very simple for her.
  7. 2016/12/29
    eisneun
    208
    socal
    Intermediate
    sorry, i didn't see that the bug had been fixed because i saw this thread from 28 dec 2016:
    Popup At Start • mozillaZine Forums
    said to have been fixed in TB 45.6.0
  8. 2016/12/29
    1,093
    Fairfax, VA
    echo $experienced;
    In the profile directory there will be a file called pref.js.
    Open it in Notepad and add this line at the bottom:
    user_pref("mail.winsearch.firstRunDone", true);
  9. 2016/12/29
    Barry
    233
    Southern California
    intermediate
    When I go to this file, this note is on top.
    * Do not edit this file.
    * If you make changes to this file while the application is running,
    * the changes will be overwritten when the application exits.
    * To make a manual change to preferences, you can visit the URL about:config
    Should I still make the change here?
  10. 2016/12/29
    843
    Dallas, TX
    Experienced
    Close T Bird and then make the changes;)
    I very much trust what Tony has written....
  11. 2016/12/29
    Barry
    233
    Southern California
    intermediate
    When I turned on her computer, Thunderbird automatically updated to 45.6.0. After restarting Thunderbird, the problem disappeared on its own. I didn't have to add the line. Thank you.
