How to share a cable modem between PC's?
Discussion in 'Networking (Hardware & Software)' started by walterm, 2002/09/06.
  1. 2002/09/06
    walterm
    walterm Inactive Thread Starter
    What do I need to share my cable connection with another PC?
  2. 2002/09/06
    Daizy
    Daizy Inactive
    Hi walterm
    Welcome to the boards.
    I use a Linksys BEFSR41 Router. Extremely pleased with it.
    Daizy
    walterm
    Did you have any problems with the config.? (set up)
  5. 2002/09/06
    Daizy
    Daizy Inactive
    Hi again!
    You know...eerily...I had absolutely none. I plugged the cables in, hit the reset...and I was good to go. It's a very popular router..... has a built in firewall.....though I still run Zonealarm as well, to catch the one or two probes taht have actually made it through. I'd not use anything else.
    Daizy
  6. 2002/09/06
    BillyBob Inactive
    Sames Router and lack of problems as Daizy.
  7. 2002/09/06
    Daizy
    Daizy Inactive
    Thanks for the back up BillyBob. :)
    Daizy
  8. 2002/09/06
    BillyBob Inactive
    You are Welcome Daizy.
    Also, as far as I know it is recommended that a Software Firewall also be run to control the outgoing traffic.
    Plus the AV software of course.
    But my Original Answer is still stands.
    Same Router and no problems.
    BillyBob
  9. 2002/09/06
    brett
    brett Inactive Alumni
    Netgear's 8-port RO318 router is certainly worthy of consideration. It is (or at least used to be) the cheapest router with SPI capabilities. The RT314 (a 4-port model comparable to Daizy's and BB's Linksys models (but with superior filtering) and also similarly priced (at ~£40 less than the RO318)) is also worth a gander.
  10. 2002/09/06
    walterm
    Thanks for the info people.
  11. 2002/09/07
    Techno
    Techno Inactive
    i know zulch about networking and teaching myself now.
    I have now set my own FTP server, + my main machine sharing a cable modem, and I am using a netgear RP114 router...works great, with built in firewall and it cost me £74.01 inc VAT + Del from my own personal PC dealer :D
  12. 2002/09/08
    Daizy
    Daizy Inactive
    Did I mention that the Linksys router is a fabulous product? :D :p
    Daizy
  13. 2002/09/08
    brett
    ... however, an aesthete could find himself/herself deeply offended after only the briefest coup d'oeil by the consequences of the insensible localization of the Linksys in a non-lapis lazuli environment.
  14. 2002/09/08
    Daizy
    Daizy Inactive
    :D ROFL!!!!!!! I'm going to totally resist saying up your lapis lazuli, Brett! Are ya quaffing again dear friend? :D
    Daizy
  15. 2002/09/08
    brett
    'Tis one of the many perils associated with having an inn within but a few strides of home, Daixy :p
  16. 2002/09/09
    Brett - check to see if they are adding odd looking tablets or powders to your libations.
    I understand there is one that will cause a period of extreme loquaciousness. Which is not in and of itself such a bad thing but it doesn't end there.
    If you find yourself penning a declaration of war on the UK (or any part of it) then you will have moved into the second phase and should seek help immediately.
    Probably best to post that one on the Virus section of the forum though.
  17. 2002/09/09
    Profgab101
    Profgab101 Inactive
    Router!
    I also use the Linksys - and as Daizy stated - you can add a software firewall to catch other "phone home" "adware" items.
    Best of all - a router allows you to only use the PC you need, and not have a "HOST" computer that is running "ICS ".
    Config is basically PnP in W2K, WXP - and also in WME if I recall currectly.
  18. 2002/09/09
    brett
    Newt wrote:
    Such things are prohibited by law. The Pure Beer Act of 1874 is still in force and provides as follows:
    That said, there is a remarkably fine oyster stout brewed locally which, whilst lacking the punch of a good yard of barley wine over Guinness, does nonetheless have a remarkably destabilizing effect :D
  19. 2002/09/09
    Daizy
    Daizy Inactive
    That explains it! :rolleyes: :D
    Anyone who drinks Fish Beer, can't be taken seriously.
    Linksys it is!
    Daizy
  20. 2002/09/09
    Daizy
    Daizy Inactive
    :eek: :eek: :eek: :eek:
    Ewwwwwww! I don't wanna know!
  21. 2002/09/10
    brett
    You don't know what you're missing, madam. I'll send you a bottle or four at Christmas :D
