Windows Vista how to remove invalid icons from control panel
Discussion in 'Legacy Windows' started by jawdoc, 2008/04/20.
  1. 2008/04/20
    jawdoc
    jawdoc Inactive Thread Starter
    Any ideas how to remove invalid icons from vistas control panel.
    I did a search for cpl and I assume that vista no longer uses control panel applications that have that extension.
    I search through the registry with no luck.
    Any help would be greatly appreciated.
  2. 2008/04/20
    jawdoc
    remove icon
    I had already done that. I wanted to remove it from the system.
    I wanted to know where these control panel applications are located.
  5. 2008/04/21
    When I do an "Advanced Search" for *.CPL I see all the Control Panel items.
  6. 2008/04/21
    Me too.
  7. 2008/04/21
    BurrWalnut
    BurrWalnut Well-Known Member Alumni
    Using Explorer go to C:\Windows\System32. Arrange the View by Type and look for files with cpl as the extension. You may have to display full filename in Folder Options to see them. Create a folder, say, TempCPL in Documents. Move the unwanted cpl files to the new folder and open Control Panel to check your removals.
