how to fix IE8 msg "running without add-ons"
Discussion in 'Internet Explorer & Microsoft Edge' started by pilotgal8, 2013/03/20.
  1. 2013/03/20
    pilotgal8 Lifetime Subscription
    pilotgal8 Well-Known Member Thread Starter
    Recovering from a motherboard failure. IE 8 gives header message
    "IE is currently running with add-ons disabled. Click here to manage, disable, or remove add-ons "
    Clicking on the message just gives me a list of add-ons just shows a list of plug ins enabled like Java and Adobe reader.
    what else do I need, and how to get rid of the annoying msg?
    Thanks in advance for your help.
  2. 2013/04/24
    Hi pilotgal8. What happens when you click on Start< Run and type iexplore.exe and hit enter? Does IE8 open normally without showing the running without add-ons message?
    What version of Windows is the computer using?
    Bocagal1
    Bocagal1 Banned
    Evan thank you for your question, but I discovered that it was probably a virus, so move the question to that session.
  5. 2013/04/24
    Bocagal1, broni is helping to remove malware infections from your computer so if you still are having problems with your computer after its declared clean then please create a new thread instead of posting in this thread. Thanks.
