How to assign static IP addresses in WinXP?
Discussion in 'Networking (Hardware & Software)' started by Alex Ethridge, 2002/03/13.
  1. 2002/03/13
    Alex Ethridge
    I cannot find where to assign static IP addresses in Windows XP. Where is it?
  2. 2002/03/13
    Kevin Lifetime Subscription
    Kevin Well-Known Member
    Start > Help and Support > static ip in the Search box
    Alex Ethridge
    I don't have XP loaded at the moment. I'll get it loaded and employ your suggestion. I have been looking for this ability in XP all over town as I work and haven found it.
    I recently bought Mark Manasi's book, Mastering Windows XP Professional. I went through the whole section on TCP/IP and looked for the word "static" in the index and it didn't show up.
    Now, maybe I can find it.
  5. 2002/03/13
    Scott Smith
    Scott Smith Inactive Alumni
    Nothings changed.
    Go to Network Places Properties/ TCP IP properties/Clear the check box for automatically obtain an IP address and type in your IP and gateway.
  6. 2002/03/13
    Alex Ethridge
    Nothing's changed? Obviously, something is different from assigning static IP addresses in Windows 98 and 2000. The whole menu structure has changed. That is the reason I couldn't find it.
    Nothing's changed in that you can still assign static IP addresses, maybe; but, how one gets to that dialog entry point has changed very much.
  7. 2002/03/13
    This from the Windows XP Help files:
    Sorry. It doesn't paste very well.
  8. 2002/03/14
    Scott Smith
    Sorry :p
    I meant nothing has changed from Win2K.
    I have been away from 98 for so long now I assumed you were migrating from 2000.:p
