How to advoid cut in printing
Discussion in 'Internet Explorer & Microsoft Edge' started by bluesky, 2002/05/21.
  1. 2002/05/21
    bluesky
    bluesky Inactive Thread Starter
    Articles in some websites have lines too long and when I tried to print them, lines were cut off at the right. Is there any way I can advoid that? Thanks.
    I use win98, IE6 and Epson stylus color 800.
  2. 2002/05/21
    In IE, click on File->Page Setup and adjust the margins.
    bluesky
    re: printing wide pages
    No. It didn't work. Since it's more like the problem with whether the page can wrap or not. And this is one of the wide page:
    http://www.linux.org/docs/ldp/howto/IPCHAINS-HOWTO-4.html
    I found 2 solutions, none of them is easy:
    1. mozilla RC2 has a feature to shrink the page to fit in printign size. The result was the letters are too small.
    2. I copied and pasted the source of the page then delete the left hand frame(and of course all the images) and the lines wrapped fine. But it took some workks to do it.
  5. 2002/05/24
    indutch Lifetime Subscription
    indutch Well-Known Member
    I just went to the link you posted and was able to get it on a sheet of paper. I only printed the first paragragh but I did get it.
    Steve's suggestion above does have some merit. With my margins set at .25 of an inch I was able to print all the text but with the margin set at .75 of an inch I lost part of the right side.
    Try 'selecting' the text you want to print. Make sure you get it all. Click on File, Print and see if you have a "Selection" option. Tick it and click OK. That should do it.
    If this works for you, thank Daizy. :) I think it was she who offered this suggestion somewhere else in the BBS.
    HTH
    Mike
  6. 2002/05/24
    Miz
    Miz Inactive Alumni
    ...Or, print it in "landscape" orientation?
    Miz,
    #5
