Resolved How reliable is Paragon System 11?
Discussion in 'Other PC Software' started by BobbyScot, 2013/09/09.
  1. 2013/09/09
    BobbyScot
    I have found one or two hiccup errors in the software. I have tried several on line addresses for help with no response to any. Can anyone help with a contact?
  2. 2013/09/09
    SpywareDr
    BobbyScot
    Thank you for contact detail. I originally contacted this address some time ago, answering printed questions - still awaiting a response. Ignoring error captions, software appears to be working, however not to comfortable in trying out saved backups until absolutely necessary.
  5. 2013/09/09
    SpywareDr
  6. 2013/09/09
    BobbyScot
    System 11 appears not work in this way as you have no choice of hard drive, only told to restart computer after clicking on Restore.
  7. 2013/09/09
    It wouldn't be a bad idea if you posted the error messages here.
  8. 2013/09/09
    SpywareDr
    Power the system down, connect the new hard drive in the current hard drive's place and then boot from your 'system 11' restore DVD.
  9. 2013/09/09
    BobbyScot
    I am unsure as to what you refer too, I have no DVD. If you refer to System 11 it is on line download from Paragon.
  10. 2013/09/09
    BobbyScot
    Errors incurred are ;
    "Snap shot could not be taken out of space. "
    Hard drive is 1TB capacity, only used for backups.
    "Unfortunately, we failed to install the recovery environment. "
    "The request could not be because of an I/O device error. "
  11. 2013/09/09
    SpywareDr
  12. 2013/09/09
    BobbyScot
    Instructions are not available with download software, or at least I can not see any other than "Why should I back up my computer ". and "Learn more about snapshots ". Lack of help for after sales makes this software not user friendly.
  13. 2013/09/10
    BobbyScot
    PeteC, my sincere thanks for online manual. I will print this off for future reference.
  15. 2013/09/10
    You're welcome :)
    A quick Google found it!
  16. 2013/09/10
    BobbyScot
    I have now made a Paragon recovery DVD-RW, is this to be used when required to make a restore when computer is down? Is this procedure required to be carried out once only?
  17. 2013/09/10
    I would think so - cf. Acronis in which the program is included on the Recovery DVD which is bootable and will run on boot. You just point it at the backup when requested.
  18. 2013/09/10
    SpywareDr
  19. 2013/09/10
    BobbyScot
    Thanks to all. Is System 11 a good software title for backups, certainly easier than Acronis this title did give me horrendous headache.
  20. 2013/09/10
