How do repair an installation of IE.
Discussion in 'Internet Explorer & Microsoft Edge' started by OLDSALTY, 2007/08/24.
  1. 2007/08/24
    OLDSALTY Lifetime Subscription
    OLDSALTY Inactive Thread Starter
    IE seems to be hanging and it never did before. I would like to remove and reinstall. Any ideas?
  2. 2007/08/24
    As you are running IE 7 there should be an entry in Add/Remove Programs - Windows Internet Explorer 7 which will revert you back to IE 6 - then reboot and reinstall IE 7.
    Before you do that though I would disable all add-ons (Tools > Manage Add-ons) and if the problem is cleared re-enable one by one until the culprit is found.
    I d/l'd IE7 to another computer on my network. Then is installer over the previous install and then fixed the problem.
  5. 2007/08/24
    Glad you managed to fix it :)
