How do I tell if my Mobo supports 64bit processing
Discussion in 'PC Hardware' started by jacrabbit, 2008/09/03.
  1. 2008/09/03
    jacrabbit
    jacrabbit Inactive Thread Starter
    with the talk of Windows 7 due to be released mid to late 2009, and that systems will be 64-bit based from there on, I know my processor is 64-bit architecture, thanks to Intels Processor ID utility, but how can I find out what my motherboard is?
    I am currently using Xp Home, which is 32-bit.
    :confused: Quote:
    "Intel(R) 64 Architecture
    64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers and applications enabled for Intel(R) 64 architecture. Performance will vary depending on your hardware and software configurations. "
    I'm Not ready to run out & buy a new system, so an O/S upgrade would be cheaper?
    Regards
    Jac
  2. 2008/09/03
    Your motherboard does not strictly speaking supports 32 or 64 bit, it supports only the CPU. If the board fully supports the CPU & your CPU is capable of running in 64 bit I think its the end of the story.
    jacrabbit
    Hi rsinfo
    Thanks for the reply, I've been searching through gigabytes site but not a lot of info there or elsewhere when it comes down to 64-bit compatability?
    Cheers
    Jac
