How do I re-enable Quick Launch feature for NS 6?
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by doctorjellybean, 2002/01/31.
  1. 2002/01/31
    doctorjellybean
    doctorjellybean Inactive Thread Starter
    Ok, after dabbling with Mozilla, the quick lanch feature of NS has disappeared. If you tell me to re-install NS 6 Ramona, I'm seriously gonna fall out with you :p
  2. 2002/01/31
    Ramona
    Ramona Geek Member Alumni
    Hey Dr.jb!
    Reinstall Netscape 6.2! Just kidding. ;)
    From the Netscape 6.2.1 Help:
    To enable or disable Quick Launch in Netscape:
    1. Open the Edit menu and choose Preferences.
    2. Click the Advanced category.
    3. Select "Enable Quick Launch" to enable Quick Launch, or deselect it to disable Quick Launch.
    4. Click OK.
    Note: It is for single profile users only.
    Cheers!
    Ramona :D
    doctorjellybean
    If all fails, read the Help file huh? Thanks Ramona !!
  5. 2002/01/31
    Ramona
    You're most welcome.
    Ramona :D
