How do I put NUM LOCK on permanently?
Discussion in 'Windows XP' started by Jetheat, 2003/10/10.
  1. 2003/10/10
    Jetheat
    Jetheat Inactive Thread Starter
    Everytime I log off, the Num Lock key goes off too. How do I get the Num Lock key to stay depressed permanently? Is there an XP setting?
  2. 2003/10/10
    Try this - search the registry (regedit) for any occurance of
    InitialKeyboardIndicators and any you find that are set to 0 (zero) change them to 2.
    Some may be set to non numeric values. Leave those alone.
    Come to think of it - that is correct. It was something that puzzled me (briefly) some time ago, but, being lefthanded, I never use the number keypad so not a problem.
  6. 2003/10/11
    Christer
    Christer Geek Member Staff
    My WinXP Pro system returns to the numlock state it is in when I shut it down. Numlock On > Numlock On and Numlock Off > Numlock Off.
    Is it possibly the Logitech Software that does this?
    Christer
  7. 2003/10/11
    Jetheat
    Thanks for the replies. I have found that there are 2 Registry values which need changing from 0 to 2.
    Found the answer in previous posts. :p
    Searched under Num Lock.
